Tried and failed to mount Stebel with the TwistedThrottle bracket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 06-16-2011, 11:26 AM Thread Starter
My fab work sucks and my tools are limited. Didn't want to shell out $$$$ for the PWD Stebel mount so I went twistedthrottle. Took ages (a month or 6 weeks?) to get the bracket. Not much to it. Tried to slap it on this morning (already ran the wiring for the most part).
Can barely fit my hands down in the space behind the fairings with the fairings on.. don't want to remove 'em again (crash bars in the way), and there's no way to verify the fairings will go on once the horn is mounted, so I figure it's best to do it in place. Hell, barely even a way to get the horn down in there.
Couldn't find a position where the horn wouldn't be hit by the forks, or rattle against the fairing. God knows, even if I found the right position, how I'd then remove the horn and keep the bracket in the same place to tighten down. Almost certainly by the time I tightened the bracket, I'd find that it had moved enough that now the horn won't fit without interfering with other things.
Oh well, probably wasn't a good idea to install something new the day before my trip anyway. *shrug* I'd just be surprised if anyone actually managed to fit the horn in that space, hanging from the left side of the fairing support bracket as in the directions.
rconti is offline
post #2 of 21 Old 06-16-2011, 11:33 AM
I can't imagine trying to do a horn mount there without taking off the cowling. Plenty of people have success doing the job but the cowling really needs to come off.
post #3 of 21 Old 06-16-2011, 12:24 PM
chicago's Avatar
I mounted an auto parts horn in the same place with a P bracket as others here have done. What Greywolf says, I can't imagine trying to work in that space with the fairing in place. I have the motech crash bars and with a little care and effort can remove the fairing with them in place.
14 tooth for me
chicago is offline
post #4 of 21 Old 06-16-2011, 01:04 PM
Voluhzia-Strom's Avatar
I installed the Stebel horn behind radiator on my Vee (in place of OEM farty) without removing anything, but swinging radiator. It had been there for not even two years, I find myself I never use horn. So I stuck the farty back...
Current bike: 2007 DL1000 V-Strom
2010: [url]http://tatadv.blogspot.com/[/url]
2009: [url]http://midwestescape.blogspot.com/[/url]
[url=http://www.facebook.com/pages/Saken-Aizhulovs-Motorcycle-Adventures#!/pages/Saken-Aizhulovs-Motorcycle-Adventures/194667233881266?v=wall]Facebook[/url]
Voluhzia-Strom is offline
post #5 of 21 Old 06-16-2011, 03:22 PM
banditrider's Avatar
It's a little fiddly even with the plastic off. Ideally you need a least three hands with kiddies fingers...
If you get it in the right position then there is no issue with the plastic getting fouled. I lucked out and got it first go.
Interesting about the delivery issues - I'm on the other side of the world and got it in about 10 days (or less) from memory.
'08 Vee: Suzy luggage, Crash bars, Rad Guard & front mudguard extension, Zumo 550, Oxford Hot grips, Stebel, PC-8, 12v acc, Scott oiler & lube-tube, Remus Revolution Cans, Bark Busters, Phillips Extreme vision +100 bulbs.
'08 Concours 14: Rad guard, Stebel, Oxford Hot grips, Projekt D Screen, Hugger, GPS mount, helmet locks & front guard extension, Zumo 550, Stebel, Phil's rack & Givi V46, Sheepskin seat cover, Phillips Extreme vision +100 bulbs.
http://banditrider.weebly.com/index.html
http://banditrider.blogspot.com/
banditrider is offline
post #6 of 21 Old 06-16-2011, 05:03 PM
jokermtb's Avatar
Looks like one could make the same thing for about $1.34 with one trip to Home Depot..........
jokermtb is offline
post #7 of 21 Old 06-16-2011, 05:21 PM
I spent closer to $5, but used a deluxe bronze pipe grounding clamp instead of a U-bolt.
post #8 of 21 Old 06-17-2011, 12:42 AM
Yep, if one had the slightest engineering skills....
post #9 of 21 Old 06-17-2011, 06:32 AM
Jimm's Avatar
The more you take the cowling pieces off the better (and faster) you get at it. There's gotta be a thread on here showing how to do that.
[FONT="Book Antiqua"]The Power of accurate observation is commonly called cynicism by those who haven't got it.
-George Bernard Shaw
[/FONT]
09 Wee ABS Silver (the other colour)
Lots o other bikes over the years
Jimm is offline
post #10 of 21 Old 06-17-2011, 07:13 AM
It's contained within Fuel Tank Removal How to, 650 & 1000
