Q - 1 AM self adj Clock - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 06-10-2011, 06:24 PM Thread Starter
Yes Read the manual, yes I went thru the 114 posts about the clock. My clock I can adjust to be correct. Then after a few cycles of having the bike running & then off the darn clock reads 1 AM all on it's own. I adjusted the clock 3 times yesterday while running around at Americade. It will start running the min I start the bike again.
Any clues out their?
Run with the big dogs or stay on the porch
STOC 1905
IBA 28154
2011 White Wee under construction
05 Wee @ 50 K ( Gone @ 56 K Loved that bike)
02 1800 Wing @ 83K
Home just outside of NYC & THE YANKEES RULE
ST114ME is offline
post #2 of 16 Old 06-10-2011, 06:45 PM
The clock isn't adjusting. It's losing power. The clock isn't the problem but the power connections to the clock. A weak battery combined with a marginal connector in the fairing is the usual cause. Hard starting or loss of headlights often follow. The connector to the instrument package is one place to check. Another is the large connector under the rubber cover in the left side of the fairing. I would also take the battery to an auto parts store and have it load tested. I also recommend a headlight relay kit to keep those little connectors from carrying the large load of the headlights. Suzuki VStrom Electrics
Electrical Connection - High Output Headlight Harness, H4, Dual
post #3 of 16 Old 06-11-2011, 06:35 AM Thread Starter
Yes the headlight did go out for a minute the other night also.
STOC 1905
IBA 28154
02 1800 Wing @ 83K
ST114ME is offline
post #4 of 16 Old 06-11-2011, 11:55 AM
Bugzy's Avatar
When i disconnected my battery, the clock kept on going, so it must have an internal battery someplace. Maybe you need to find/replace that?
Bugzy is offline
post #5 of 16 Old 06-11-2011, 12:16 PM
There is only one battery. There may have been a capacitor holding a charge for a bit but that's it.
post #6 of 16 Old 06-11-2011, 12:18 PM
V-Tom's Avatar
Also check your battery terminals if you haven't already.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #7 of 16 Old 06-11-2011, 02:21 PM
I have an FJR that did the same thing. Drove me crazy.
Turned out it was the battery getting weaker.
Got a new battery. Problem solved.
In fact it is a good warning system that your battery is starting to go and needs to be replaced before it strands you.
RC
rogerc is offline
post #8 of 16 Old 06-11-2011, 03:36 PM Thread Starter
The battery is not a year old? Has never been discharged & spent the winter on a charger?
Is a dead battery even possible at this point?
Every rider I know seems to get 4 or 5 years out of a battery & I seem to go through them like hotcakes.
STOC 1905
IBA 28154
02 1800 Wing @ 83K
ST114ME is offline
post #9 of 16 Old 06-11-2011, 03:42 PM
Have the battery load tested. Check connections. Check the charging system.
post #10 of 16 Old 06-12-2011, 01:25 AM
replacement battery
Depends much on what replacement battery you got, they most certainly are not all equal. Yes it's not all that uncommon for a replacement battery to be going dead and it's only a year old.
Bill H.
griffin800 is offline
