DL1000, please help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 06-09-2011, 01:45 AM Thread Starter
DL1000, please help
Just picked up an '06 DL1000 a few weeks ago and have a couple of issues. One, my temperature gauge will not go to third bar as it should unless I idle it for a while but when I start moving, it drops down to second bar again, I thought it was the temperature sensor so I replaced it, now I know what it is NOT. I find it difficult to believe it would be the dash gauge itself, thermostat seems to operate ok, bike starts & runs ok,even the GPM's seem good ( just under 50 GPM cruising. One thing however concerns me, after a cold start, I notice in my underground garage, the front cylinder exhaust pipe is glowing a little due to excessive heat. My old DL 650 did none of this. It seems to me the glowing and low temperature are somehow related but can't come up with anything. Any ideas ? Thanks for reading
700-X is offline
post #2 of 17 Old 06-09-2011, 02:12 AM
There's nothing unusual about a glowing front header. That's perfectly normal.
Where I ride, 2 bars is normal, three at a long light. I've seen four bars a few times where it's really hot and I'm idling or working a difficult off road section. I've never seen five bars, that'd be bad. I'm not certain there's anything wrong with your bike. Now, if you'd told me it won't rise above a single bar in normal riding, I'd say you should be concerned.
If you think the temp gauge is confounding, wait till you notice how the fuel gauge works. With a full tank, the first bar disappears after about 90 miles of gas, the second bar after 50miles, The third at after 30 miles and the fourth after 20. That last bar starts blinking after another 10 miles and both bar and fuel indicator start blinking another 10 miles later. Of course, YMMV. :-)
Cake_Kat is offline
post #3 of 17 Old 06-09-2011, 05:23 AM
pvwheeler's Avatar
Two bars is normal for the Vee,unless you are stuck in traffic.
Steve
2015 Wee2 EXP "Arya"
2002 DR650 SM "Tormund"
2014 CB500x (wifes)
2018 XT 250 (wifes)
pvwheeler is offline
post #4 of 17 Old 06-09-2011, 05:35 AM
I only had 2 bars while riding last weekend here in Texas with 95+ Farenheit temps; went to 3 at lights.
Mike
07 Vee
falmike is offline
post #5 of 17 Old 06-09-2011, 06:15 AM
2tall's Avatar
Who told you it should be at 3 bars? Just ride the thing!
John
johnvstrom at yahoo.ca.............. V-Stromming since '03
'06 DL1000 Grey
'03 DRZ400$ sold, down to one bike
2tall is offline
post #6 of 17 Old 06-09-2011, 06:51 AM
We've had 100 degree day's already and it only hits 3 bars after sitting at traffic light for few minuets. Then back to two after start moving again. Speaking of coolant. How much antifreeze does it take to top off the radiator after a flush? Do you mix it 50/50 or run straight antifreeze? This is my first water cooled bike. All the others had the cylinders sticking out in the breeze.
BornAgain is offline
post #7 of 17 Old 06-09-2011, 07:28 AM
Mine runs at 2 bars, goes up to three at a light.
CDHat is offline
post #8 of 17 Old 06-09-2011, 07:30 AM
50/50 anti-freeze mixture is what you want.
itsak9 is offline
post #9 of 17 Old 06-09-2011, 09:35 AM
2tall's Avatar
I've never done mine but here's what the service manual says...
Engine coolant type: Use an anti-freeze/coolant compatible with aluminum radiator, mixed with distilled water only, at the ratio of 50:50.
Engien coolant (yes typo is in the manual )
Reserve side: 250ml (0.3/0.2 US/Imp qt)
Engine side: 1950ml (2.1/1.7 US/Imp qt)
John
'06 DL1000 Grey
2tall is offline
post #10 of 17 Old 06-09-2011, 10:21 AM
Boy wait till he sees all the other quirks...
chudder sprocket 30mpg noise front springs R/R stator TBS map ......BOING!
richw is offline
