Red light at idle - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 06-07-2011, 07:31 PM Thread Starter
350DRYDER's Avatar
Red light at idle
I have a 2007 Vee that a buddy and I just did some maint. on . We set valves , flushed coolant, synced T/Bs. We put it back together and I noticed at idle my volt dummy light was flickering red. Idle is 1250rpm and all electrical connections that were unplugged are plugged and secured. I've put about 350 miles on it and it seems to run great but now it has a solid red light at idle. My thought is it could be the original battery finally going bad. It turns over freely and fuel pump bu
ilds quickly .It fires right up. I just don't want to walk out some day to a dead battery. Any suggestions ?
Hi, I'm back. I just installed a new OEM stator. I thought it went quite easy until I took the NO LOAD reading and all three contacts read 67-68 volts. I used two different R/R's and only have 12.8 at the batt. The service manual says (more than 75V at 5000rpm hi beams on engine cold)and 14-15.5at batt. Looking for answers
350DRYDER is offline
post #2 of 18 Old 06-07-2011, 07:46 PM
I guess what I would do in that situation is to break out my DVM, but any digital or analog would do, and measure the voltage directly across the battery during idle, ( 13.8 to 14.2 ) and before start with all switches off position. ( 12 or close to) And compare to that seen on the terminals of your "volt dummy light" and look at the documentation for the volt dummy thing ya got there and see if it's working as advertised. This actual data could also give ya an idea how your battery / charging system is doing as well.
StormWee is offline
post #3 of 18 Old 06-07-2011, 07:49 PM
Are you getting an FI at the clock position or are all the temperature bars full. If not, it's an oil pressure warning light. It would be a good idea to check the oil pressure. It should always be between 14 and 57psi. If it's okay, the sender is suspect.
post #4 of 18 Old 06-07-2011, 08:15 PM Thread Starter
350DRYDER's Avatar
Thanks StromWee I'll try that. I'll test the batt. also. Grey Wolf I think you may have missunderstood .This is an add on light. There are no codes coming up on the guage cluster, they all seem normal.
post #5 of 18 Old 06-07-2011, 09:04 PM
So it's a voltage level add on light. Checking the actual voltage with a meter would be the first thing then. For better voltage at idle if everything is working, a MOSFET regulator/rectifier is the best bet.
post #6 of 18 Old 06-08-2011, 01:16 PM
Well, the first question is what's the light connected to? Until we know that, we're just guessing... It could be connected to a whole bunch of different things...
gijoecam is offline
post #7 of 18 Old 06-08-2011, 06:16 PM
Ranger Ron's Avatar
Is it a Chargalert by any chance?
Ron
Ranger Ron is offline
post #8 of 18 Old 06-08-2011, 08:40 PM Thread Starter
350DRYDER's Avatar
The light is connected to a Blue Sea fuse box. It's an ELECTRICAL CONNECTION battery monitor.
post #9 of 18 Old 06-08-2011, 09:58 PM
I have a 2007 Vee ... My thought is it could be the original battery finally going bad. It turns over freely and fuel pump builds quickly .It fires right up. I just don't want to walk out some day to a dead battery. Any suggestions ?
Yes, go with your instinct on this and replace your battery. Its 4 years old and you state that the battery volt dummy light is now red indicating a low voltage condition. Throw a new battery in there, clean up the connections and make sure they are tight. Peace of mind is now yours.
StormWee is offline
post #10 of 18 Old 06-09-2011, 06:22 PM Thread Starter
350DRYDER's Avatar
Charged battery over night and had it checked at Advanced Auto . The good news is ; the battery is good . The bad news is ; the battery is good !
