Why lube chain? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 06-03-2011, 02:45 PM Thread Starter
Why lube chain?
Now this is a strange question coming from someone that has been riding since the '50s, albeit many miles with a shaft drive, but yesterday after using the Kettenmax to clean the gravel grime off my V-Strom's chain and proceeding to dutifully apply DuPont Teflon I asked myself "just what are you lubing?' I dribble the Teflon over the o-rings then on the center of the chain but why? Is the purpose just to keep the o-rings from drying out? Surely the Teflon on the driven part of the chain will have a short life (and probably end up under the drive sprocket cover).
I've followed the clean then lube duty religiously and always get 15 k to 25k miles before I change the chain and sprockets and never questioned the need, until now.
Thoughts?
keetmanaa is offline
post #2 of 10 Old 06-03-2011, 02:58 PM
Start with post #18 at https://www.stromtrooper.com/v-strom-...g-chain-2.html
post #3 of 10 Old 06-03-2011, 03:37 PM Thread Starter
Interesting! I guess it's not a new question. After reading through the threads (thanks for the links) I come to the conclusion that the two main purposes of my lubing the chain are: 1) keeping the o-ring fresh and 2) lubing the bushing to roller contact.
I think I'm doing the o-ring lube correctly by "dribbling" the Teflon onto the o-rings on both sides of the link but I guess I should direct the spray nozzle to the junction of roller/ bushing in hopes some will make it into the space between.
post #4 of 10 Old 06-03-2011, 05:12 PM
Evolving Curmudgeon
kick's Avatar
A quality chain lube also provides a lubricating barrier between the chain to sprocket contact points, greatly extending the life of each.
'07 WEE-HAAAA! Blue, loaded & sweet
I'll know where I'm supposed to be when I get there.
kick is offline
post #5 of 10 Old 06-03-2011, 10:19 PM
DL1000 specifically
With my 06 DL1000 I have been liberally applying good quality chain lube and never was too concerned about fling. Always believed that more is better than less. I recently pulled front sprocket cover and clutch slave cylinder and was faced with hugh amount of packed up oily dirt and gravel that had been hampering clutch push rod. So now for me it will be strictly limited amount of WD40 with hope to minimize this clutch interference. WD40 is too light for best chain lube but will be only lube for my Vee.
On my other bikes I will continue to use good quality chain lube and clean up after lube fling.
04 Kaw KDX220
06 Suz DL1000
09 Suz DR650
11 Kaw KLE650 Versys
oldturtle is offline
post #6 of 10 Old 06-03-2011, 10:36 PM
swingset's Avatar
Send a message via Yahoo to swingset
Teflon dry-lube is a vastly better lube than WD-40, and will not fling or muck up the push-rod area.
Never met a dog I didn't like, a machine I couldn't break, or a woman I couldn't tick off.
swingset is offline
post #7 of 10 Old 06-03-2011, 10:37 PM
Dupont multi purpose dry wax lube with Teflon or Bel-Ray super clean are both excellent chain lubes that will not cause a major sticky build up in that area.
post #8 of 10 Old 06-04-2011, 03:19 AM
Just had a look at the front sprocket area after 25,000 kms. The build up from Du Pont was a very small amount compared to chain lube fling and mung I found from the previous 25,000 kms.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #9 of 10 Old 06-04-2011, 08:55 AM
randyo's Avatar
you ask the question as if yer shafts didn't need lube
ANY metal to metal contact point needs lubrication or the metal (sprocket teeth/gear teeth)will heat and bend and break, for the same reason gears in a cars rear end need lube
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #10 of 10 Old 06-05-2011, 05:05 AM
Also
I would expect that rust accumulation on a chain would wear the sprockets in pretty short order. And I imagine that the o-rings need some lube to keep from wearing out as the chain repeatedly flexes. The modern 'superclean' lubes seem to work well without significant accumulation of grunge. WD-40 has little if any anti-rust capability (based on my experience with garden tools) and I'm not confident in its ability to provide lubrication long term. Works well for its intended purpose of driving out water, though.
Jimding is offline
