Lowered the bike by 3/4. How much do I cut the stand? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 05-31-2011, 07:13 PM Thread Starter
Last year, I lowered the bike 3/4 inches front and back. How much do I cut down the stand? I'm guessing 1/2 inch but not sure. Also, if I put back the old links, will the bike be stable with that extra half inch shortened stand? Or do I have to reverse the process?
BTW....I'm doing my own work sod have plenty of steel/fabricating abiity so if anyone has any advice on changing anything, I'm all ears.
Spartan is offline
post #2 of 8 Old 05-31-2011, 07:52 PM
randyo's Avatar
when I lowered mine, I didn't bother cutting the sidestand down, at stock height, I think it leans too much to begin with, but I did grind the mount so that the stand would swing forward a wee bit further and lock into place better
now I'm back to stock height and I think it leans too much again, forgot how awkward it can be righting the top heavy bike from the sidestand while straddling it on yer tip toes
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #3 of 8 Old 05-31-2011, 08:22 PM
I concur. I had my bike lowered 3/4" front and back for a couple of years. All I did was make sure it wasn't parked where the side stand foot was on a high spot.
post #4 of 8 Old 05-31-2011, 09:30 PM
Trial and error will solve. Roll tires onto 1/2" plywood in level garage and check lean. Just add or subtract from 1/2" plywood until you get lean right. When satisfied with lean - measure sidestand cut off length at same angle as sidestand which will be slightly longer than final thickness of plywood.
04 Kaw KDX220
06 Suz DL1000
09 Suz DR650
11 Kaw KLE650 Versys
oldturtle is offline
post #5 of 8 Old 06-01-2011, 07:47 AM
Nova Scotia Strommer's Avatar
https://www.stromtrooper.com/dl650-sp...tml#post675944
you could try this.
09 DL650 ABS ORANGE "Form over function at a superior price"
09 DR650 "Hooliganizer"
03 TW200 "No Roads....No Problem"
02 TW200 "Redneck Edition"
Nova Scotia Strommer is offline
post #6 of 8 Old 06-01-2011, 03:59 PM
cut off 1". I lowered my wifes wee 3/4" and this is perfect. insert a steel rod inside for strength.
icnxpln is offline
post #7 of 8 Old 06-03-2011, 10:03 PM
gsinpei's Avatar
Don't need to cut anything it should be fine.
gsinpei is offline
post #8 of 8 Old 06-03-2011, 10:25 PM
mhoffm's Avatar
3+ years lowered 3/4 front and rear. No issues with stock length stand.
2007 Triumph Bonneville
2007 DL650 (Prev bike)
mhoffm is offline
