Handguards rigged for WeeSTrom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 05-29-2011, 01:58 PM Thread Starter
jokermtb's Avatar
I bought some scratched and dented handguards from someone online. The lower holes in each guard were torn out, and the longer brake/clutch lever pin bolts were not included. Determined to make my $30 investment work, I took apart my bar end weights, milled off about 25mm of the metal shaft/rubber so that when I added in the requisite guard bar-end spacer, I'd still be able to get the rubber donut to expand when I tightened up the bar end - it worked, and I didn't have to buy longer bar end bolts. Thanks to all you who posted that thread about NOT removing the bar end bolt all the way! I didn't have to fish around for the rubber nubbin bolt inside the handlebar!
As for the busted plastic guard mount holes, I fashioned up a crude aluminum bracket that I would use the clutch pivot bolt as an attachment point. The other end of the bracket would bolt to a new hole drilled into the bottom of the handguard plastic [blue loctite used!]. Bolted everything so, and the guard is rock solid! Did the same in a similar style for the brake side. Glad to that everything lined up and I didn't have to worry about infringing on the clutch saftey switch's airspace.
I'm pretty happy with the results!
jokermtb is offline
post #2 of 4 Old 05-30-2011, 08:58 PM
I believe I know where you got these bad boys :mrgreen:
Glad they worked out for you!
MiteyF is offline
post #3 of 4 Old 05-31-2011, 11:16 AM
rockitcity's Avatar
Glad it worked out for you, but I can't understand why you'd spend $30 and who knows how much of your time to kludge together something you could have bought new for about $20 more. I do understand the "more time than money" syndrome, but for me the spread was usually much larger than $20.
Then again, if you had just bought new ones, you wouldn't have the satisfaction of saying you did it yourself.
In any case, enjoy your new handguards!
2013 Triumph Tiger Explorer
rockitcity is offline
post #4 of 4 Old 05-31-2011, 11:45 AM
2tall's Avatar
I can't get over the fact he charged you $30.00 for them!
John
johnvstrom at yahoo.ca.............. V-Stromming since '03
'06 DL1000 Grey
'03 DRZ400$ sold, down to one bike
2tall is offline
