Oh No, Too Much Oil - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 05-27-2011, 11:51 PM Thread Starter
Oh No, Too Much Oil
Just put a center stand on my new to me '08 Wee. The oil was above the top fill line. I drained about 4-5 ounces to bring it to the correct level. The place I bought it from over filled it and I rode it for about 200 miles before I corrected it. Do I face any future problems?
Grkane is offline
post #2 of 14 Old 05-28-2011, 03:03 AM
5 fluid oz is 148 ml of extra oil. The bike takes 2700 ml total. I don't think it will be an issue.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 14 Old 05-28-2011, 04:34 AM
ockerstrom's Avatar
There won't be a problem with that amount over.
Better than being under
Ock. in Oz
I ride naked and unafraid.
Windsor (near enough)
NSW
Australia
ockerstrom is offline
post #4 of 14 Old 05-28-2011, 05:03 AM
Originally Posted by Grkane View Post
Just put a center stand on my new to me '08 Wee. The oil was above the top fill line.:
i take it you were checking the oil while the bike was on the centre stand?
if you were then that is the issue, the bike should be on both wheels on level ground, hold the bike vetical and then check the oil level. this is the method that the owners manual suggests for checking the oil level.
the centre stand will tip the bike slightly forward and skew the amount of oil you think you have.
:beatnik:
tired of the spam from this site, gone down hill since 2010
Dazinga is offline
post #5 of 14 Old 05-28-2011, 07:07 AM
ockerstrom's Avatar
:beatnik:
The difference between checking while holding the bike upright compared to checking while on the centre stand is negligible and will cause no issues.
I'm betting the place Grkane bought the bike from had an apprentice check the oil level and it was done while the bike was on the side stand.
Ock. in Oz
NSW
Australia
post #6 of 14 Old 05-28-2011, 11:23 AM
Issues
The only real issues with overfilling are oil foaming and oil overheating. If the oil level is high enough that the crankshaft is running in the oil, it will tend to whip the oil into foam, which lacks lubricative ability, and overheat it, due to the additional drag on the crank. Kinda doubt the slight overfill would generate either of these problems. Severe oil overfill may also splash excess oil on the cylinder walls, increasing oil burn, but that tends to be self-limiting (other than perhaps fouling the plugs, if long term). So no need to worry.
Jimding is online now
post #7 of 14 Old 05-28-2011, 02:55 PM
Cowboys aint easy to love
dancer's Avatar
The advice by Dazinga is correct.
Unless I've had a lifetime of bad advice, the primary reason not to overfill oil levels in crankcase sumps is to prevent excess crankcase pressure from being developed that will blow out critical seals.
Stromless
'97 Honda Valkyrie
I believe in ... gravity!
"Everyone brings something to the party."
- Snoopy
dancer is offline
post #8 of 14 Old 05-29-2011, 12:43 AM
:beatnik:
This has been my experience as well.
'06 Suzuki DL650
'09 Vespa GTS 250ie
acududeman is offline
post #9 of 14 Old 05-31-2011, 10:32 AM
over fill
I'm not sure about seals but my 2004 wee was overfilled by the previous owner. I found oil in the airbox when I checked the filter. I lowered the level to the line on the sight glass and it hasn't moved a bit 2000 miles. I'm thinking when I check the filter again it won't have oil in it.
post #10 of 14 Old 05-31-2011, 11:09 AM
kenneth_moore's Avatar
I was getting ready to ride to Bike Week last year and a Harley guy at work who was going told me: "I'm going to put an extra quart in for the trip." I kid you not. I talked him out of it.
This year he couldn't go because the oil drain plug mysteriously "fell out," causing over $3,800 in damage to the transmission. He said it was the dealer's fault because "they had it in the shop a few weeks ago and should have seen it." He had been bugging me to change his oil for him a couple days before the ride...I didn't have time, thank God.
Go hakafugu yourself.
kenneth_moore is offline
