Source Of compressed Air For Flat Tires: WIll It Work? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 41 Old 05-27-2011, 09:50 AM Thread Starter
echo's Avatar
Its for paint ball guns.
Home > Tanks & Tank Acc. > Compressed Air - HPA > Guerrilla Air Paintball Tanks >
Guerrilla Air Compressed Air Tank W/ Myth Regulator 62/3000 - Black
Our Price: $57.95
Sale Price: $39.95
You Save $18.00
Availability: Usually Ships in 24 Hours
Product Code: YSNGUERRILLA623000TANK Qty:
Description Guerrilla Air Compressed Air Tank W/ Myth Regulator 62/3000. This tank is in stock and ready to ship! Features
The All-In-One Revolutionary Myth regulator and tank systems
High Pressure Air System That Screws Directly to Your Gun
3000psi Aluminum Cylinder with a Pre-set Output
Highest-Performance
Lowest-Profile
Lightest-Weight
echo is offline
post #2 of 41 Old 05-27-2011, 11:52 AM
eye.surgeon's Avatar
Two essential accessories on every bike I own: a powerlet plug and an air compressor for motorcycles, that and a quick tire plug kit both fit under the strom seat. You don't have to reinvent the wheel, the solutions are already out there.
'09 Wee (sold)
2012 Ducati Multistrada 1200 S Touring
2006 BMW K1200LT
eye.surgeon is offline
post #3 of 41 Old 05-27-2011, 11:54 AM
seuadr's Avatar
this.. you can pick up a slime brand one that will fit under the seat (little larger and thicker than a pack of smokes) for 9.99
It's a funny thing about comin' home. Looks the same, smells the same, feels the same. You'll realize what's changed is you.
seuadr is offline
post #4 of 41 Old 05-27-2011, 12:34 PM
Mud Puddle's Avatar
Yea...I would just buy an actual compressor. I got this one.
Amazon.com: Slime 40001 Power Sport Tire Inflator: Automotive
Shop around and you can find it cheaper.
09 "Wee"-Strom DL650 (Orange)
99 Harley-Davidson XL1200S
00 Bultaco
73 Bultaco Sherpa-T
Mud Puddle is offline
post #5 of 41 Old 05-27-2011, 12:37 PM
Tall Man's Avatar
Tall Man is offline
post #6 of 41 Old 05-27-2011, 01:21 PM Thread Starter
echo's Avatar
The Slime pump work for five minutes then it must be shut down because it overheats. In that time its adds 5 psi to the typical motorcycle tire. I am not impressed.
How many tires could you fill with air from a paintball can @ 3000psi?
echo is offline
post #7 of 41 Old 05-27-2011, 01:31 PM
jeems's Avatar
Can't vouch for or against the slime, but to not quite answer your question, it depends on the size of the tank.
DL650K6
If not actually disgruntled, he was far from being gruntled. - PG Wodehouse
jeems is offline
post #8 of 41 Old 05-27-2011, 01:36 PM
bwringer's Avatar
You must have gotten a bad one. My Slime pump works fine, as do thousands of others. I've pumped up several motorcycle and car tires with no issues or shutdowns.
Tanks of Co2 are expensive and very limited -- once you run out, you're stuck. With a compressor, you have an unlimited supply of air. Even if your tire plug has a slow leak, you can at least stop and top it up again as needed in order to limp back home.
bwringer is offline
post #9 of 41 Old 05-27-2011, 01:53 PM Thread Starter
echo's Avatar
Have you ever filled a tire with zero psi in it? The instructions say dont run the bikes engine. You aint filling an empty tire on the bikes battery.
I just wonder how much air is on one of those air tanks. If you could do two or three tires for $50 purchase price it would be great.
echo is offline
post #10 of 41 Old 05-27-2011, 02:25 PM
V-Strom Ry's Avatar
If you'd provided a link, I coud look and see exactly what it is you're talking about. I assume this is a refillable tank and probably doesn't come pre-filled with air. Where would you get it refilled? Will it hold air indefinitely? How do you get it hooked up to an air hose chuck?
I've refilled seriously low car tires (after fixing a flat) with my 12V compressor without any great trouble. The instructions that came with it said to let it have a rest after something like 15 minutes of continuous running. And I have run the engine on the bike while using it at times - keeps the voltage up.
V-Strom Ry is offline
