bar-ends - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-25-2011, 11:52 PM Thread Starter
bar-ends
I've got a extra set of bar-ends, they're from a dl1000. I also have a set on my dl650. I just discovered the two on my bike are not the same diameter, though close. one is 32mm(1 1/4") , ... the other 36mm (1 7/16").
I have no idea which size is the OEM set for the dl650. Could someone please measure theirs... best to get actual sizes measured on each dl model.
Thanks a lot, dave
bower100 is offline
post #2 of 5 Old 05-26-2011, 06:37 PM Thread Starter
Cum'on guys...the difference is obvious enough by just holding a ruler up to them. Post your bike model and the size.
They're either: 1 1/4"....... or 1 1/2"
Thanks a bunch, dave
bower100 is offline
post #3 of 5 Old 05-26-2011, 09:22 PM
Stalky Tracker's Avatar
Ok, I'll play.
DL650 and my bar ends are 1.25" diameter.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 5 Old 05-27-2011, 09:50 AM Thread Starter
Thank you, thank you.
Something posted just today has a photo of the 650 bar-end assy. too
How convienient. So, unless I'm wrong the 650 has somewhat smaller end weights than the 1000.
I guess that might make sense. Dunno.
dave
bower100 is offline
post #5 of 5 Old 05-27-2011, 01:11 PM
rockitcity's Avatar
Funny you mention that. I bought a Kaoko throttle lock that replaces the right bar end. On ordering it spceified fitting either a DL650 or 1000. The lock is larger diameter than the 650 bar end. Don't know if it would match a 1000 or not.
2013 Triumph Tiger Explorer
rockitcity is offline
