Hand Guard bolt question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-25-2011, 03:12 AM Thread Starter
Right ( brake) side hand guard bolt loosened up and fell out on my ride home last night. I looked up the bolt & the acorn nut that belongs their & they just had Suzuki PN's no sizes. Does anyone know what size that bolt & acorn nut are. I have a rubber band through the hole now holding the hand guard in place & that just will not due.
When I go to the hardware store tomorrow I need some sizes & a description.
Thank you Bill
Run with the big dogs or stay on the porch
STOC 1905
IBA 28154
2011 White Wee under construction
05 Wee @ 50 K ( Gone @ 56 K Loved that bike)
02 1800 Wing @ 83K
Home just outside of NYC & THE YANKEES RULE
ST114ME is offline
post #2 of 7 Old 05-25-2011, 09:17 AM
take the
Take the left bolt to the hardware store (ACE & Truevalue have a good selection) and match it up. Make sure they get you a metric bolt, lots of sales folks don't think it makes any diff.
sweetcreek is offline
post #3 of 7 Old 05-25-2011, 09:22 AM
bcnu53's Avatar
Send a message via Skype™ to bcnu53
good luck in your search. I tried and gave up could not find at hardware store and Suzuki dealer would not sell each. had to buy another setup
bcnu53 is offline
post #4 of 7 Old 05-25-2011, 09:28 AM
I have an ample supply of SS Metric M6 Bolts........lengths from 10mm long to 65mm. Also a couple of M5 sizes. I'm not familiar with the handguard bolts (I have Barkbusters), but shoot me a PM if you need any M6 bolts to fix your guard. None of mine are "shouldered" if that is a requirement??
(Note: M6 is probably the most common size on the bike......engine covers, handlebar controls, etc)
www.easternvstromrally.com
mark444 is offline
post #5 of 7 Old 05-25-2011, 09:44 AM
The lever pivot bolt is shouldered and the shoulder is the bearing surface for the lever. It is tapped on top for a small screw and has threads on the bottom for an acorn nut. The pivot bolt can't be replaced by a hardware store item. The top screw and bottom nut can. which of the three parts went missing?
post #6 of 7 Old 05-25-2011, 11:07 AM Thread Starter
Now that it's not dark anymore I got a chance to look at it. I wrote the question at 3 something this morning ( old guys don't sleep much). The top screw jumped ship. I was able to replace it at the hardware store with a metric Allen screw and a washer. Picked up a bottle of locktite also. Can't have these things jumping ship like that. I also tightened up the other side which was loose.
Lesson to all - GUYS TIGHTEN THESE DARN THINGS !
Thank You
Bill
STOC 1905
IBA 28154
02 1800 Wing @ 83K
ST114ME is offline
post #7 of 7 Old 05-25-2011, 11:16 AM Thread Starter
2nd lesson -GREYWOLF ROCKS
STOC 1905
IBA 28154
02 1800 Wing @ 83K
ST114ME is offline
