putting on the dam spring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 05-24-2011, 09:43 PM Thread Starter
bschoolz1's Avatar
all right i tried my way to get the spring on my center stand. i figured id tap all the knowledge on this site. theres got to be another way
bschoolz1 is offline
post #2 of 11 Old 05-24-2011, 10:05 PM
TOScootz's Avatar
Not trying to be rude, but search for it. That questions gets asked a couple of dozen times a year.
TOScootz is offline
post #3 of 11 Old 05-24-2011, 10:09 PM
Tollster's Avatar
otherwise, put on your saftey glasses,fold up the center stand and wire it in place, then use a screw driver and leverage it over the pin ising the pin as the lever. It will take more than one attempt. You'll buy one next time...trust me.
Tollster is offline
post #4 of 11 Old 05-24-2011, 10:22 PM
You can use a bit of poly cord wrapped between the spring and a spoke on the rear wheel. Roll the bike forward and the spring will pop onto the stud.
Cake_Kat is offline
post #5 of 11 Old 05-25-2011, 02:49 AM
maxblack's Avatar
Spring puller, the best way, as suggested by Tollster.
Orange DL 650 L0 :mrgreen:
maxblack is offline
post #6 of 11 Old 05-25-2011, 03:02 AM
LordSmoke's Avatar
https://www.stromtrooper.com/dl650-sp...llation-2.html
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #7 of 11 Old 05-25-2011, 08:46 AM
DougP's Avatar
Send a message via Skype™ to DougP
Put everything together to where the last things needed is to put center stand into place where the pivot bolts go on and install the spring. Get another hand if you can. Put the springs on without putting the center stand in the pivot mountings, then pull it in to place for the pivot bolts and slide the bolts into place. The center stand itself gives you enough leverage to do this. I did it by myself, but like I said, another hand is helpful. No spring pullers needed. It was an easy job.
DL650K7
OEM Center Stand, Givi E460, E41 Cases, SW-Motech QR racks, Russell Day Long, GIVI windshield, BarkBusters, Madstad, Aprilia Mirrors, Touratech GPS holder
DougP is offline
post #8 of 11 Old 05-25-2011, 10:11 AM
cdherlils's Avatar
For me it was a pair of flat nose adjustable pliers, and with the center stand tied into the up position, I grabbed the center spring and attached it. After that I then grabbed the outside spring and connected that.
This was a easiest and fastest part of the whole install.
2009 DL650 Oort Gray Metallic Edition
1985 Honda Rebel CMX250C
(Bike rescue/rebuild project)
2003 SV650 Fast Silver Edition
If it aint broke, take it apart and make it better.
cdherlils is offline
post #9 of 11 Old 05-25-2011, 11:44 AM
Location: Honolulu, HI Bike currently in Salt Lake City
I found it to be very easy using two people. I pulled each spring forward using a nylon cord, pulling from each side of the front wheel. My friend popped the springs on with a screwdriver. I installed the OEM stand.
DC
dc808 is offline
post #10 of 11 Old 05-25-2011, 09:14 PM Thread Starter
bschoolz1's Avatar
spring
did the wire trick between the wheel very easy
