Help Please 2008 Canadian DL 650 only Two Spark Plugs? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 05-21-2011, 06:20 PM Thread Starter
Hi Fellas
I am in the process of doing some maintenance.
My 2008 Canadian Wee appears to have only 2 spark plugs?
I thought they had 4 ?
Toto is offline
post #2 of 11 Old 05-21-2011, 06:59 PM
There are four. You can see the two plugs on the sides. The others are buried in the center of each cylinder.
post #3 of 11 Old 05-21-2011, 07:23 PM Thread Starter
Thanx Muchly...toto
Toto is offline
post #4 of 11 Old 05-21-2011, 10:22 PM Thread Starter
Got em all...that front plug was a bitch...easier to put on my Scotts Damper.
BTW I did the Scotts at the same time as the air filter and plugs.
Very staight forward....no filing to be done.
Now I just have to put the cowling back on.
Toto is offline
post #5 of 11 Old 05-22-2011, 12:11 PM
honest bob's Avatar
Very easy to get at if you first remove the rad and it's cowling. While you are in there (if not too late) check to see if the drain holes on the center plugs are open.
honest bob is offline
post #6 of 11 Old 05-22-2011, 02:10 PM Thread Starter
Thanx for the tip...if I ever do it again I will remove the rad fro the frame.
I just undid it and swung it out a bit, tough job.
I put Iridiums in and don't plan to change 'em for quite a while.
Toto is offline
post #7 of 11 Old 05-24-2011, 01:26 PM
honest bob's Avatar
You may want to check the back of your rad to see that most of the fins have not been turned flat by your knuckles.
post #8 of 11 Old 05-31-2011, 11:09 PM Thread Starter
Well, Bob, I did check....and sure eneogh...some of them did get bent...fixed as best I could...no overheating and it was hot as hell today.
Toto is offline
post #9 of 11 Old 06-01-2011, 10:40 AM
pso
Toto, how did your plugs look and how many miles?
pso is offline
post #10 of 11 Old 06-01-2011, 11:00 AM
Martin's Avatar
I just changed my plugs on the weekend... swinging the rad forward and using a bungy to hold it out of the way works fine *if* you use the spark plug tool provided with the bike... it's just the right length.
It took me less than an hour... mostly spent removing/reinstalling the tupperware. My 2005 only has two plugs though.
- Martin
2019 650X
Martin is offline
