Clutch line rerouted - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-19-2011, 08:44 PM Thread Starter
CHUPACABRA's Avatar
Just wondering if there is an easy, quick way to reroute the clutch line behind the bars without having to bleed the whole system. I ordered some 2" ROX risers and don't think the clutch line is long enough without relocating it.
CHUPACABRA is offline
post #2 of 7 Old 05-19-2011, 09:07 PM
Appalachian Rider's Avatar
Its been a while since I installed my risers but I believe there is a mounting bracket that holds the line close to the steering stem (below the upper triple tree). I simply took the line out of the bracket and removed the bracket to put in storage. The clutch line now has plenty of slack. Hope that helps.
Farkle Free Signature
Appalachian Rider is offline
post #3 of 7 Old 05-19-2011, 09:14 PM Thread Starter
CHUPACABRA's Avatar
Yes, I see that and plan on removing it and the one for the brake line also, but it doesn't look like I'll gain 2"
post #4 of 7 Old 05-19-2011, 10:58 PM
K1W1's Avatar
Not sure whether it would be easy or quick but the ONLY way will be to take the left side hand grip off and slide the clutch assy off the end of the bar then re route it and put it back on the back. You'll have to remove the bar from the triple clamp but you were going to do that anyway.
K1W1 is offline
post #5 of 7 Old 05-19-2011, 11:14 PM
cbrxxcess's Avatar
Send a message via Yahoo to cbrxxcess
I pulled my hose off and rerouted it to the other side and put it back on. If you then get the bolt close to being tight and then squeeze the handle and tighten the bolt down you will be fine. It took me all of 30 seconds. I too have the Rox risers but make sure you have the slack you need in the line. It seems to me there was bracket that was bolted to the frame close by and I took that off first.
Keep the Rubber Side Down.
Jim
Present Rides
1986 XR600R,1986 VF1000R,1999 CBR1100XX,2006 CRF450X,2007 DL1000 V-Strom
[IMG]http://i412.photobucket.com/albums/pp210/cbrxxcess/Motorcycles/North%20American%20V-Strom%20Rally%202009/Canadamap.jpg[/IMG][IMG]http://i412.photobucket.com/albums/pp210/cbrxxcess/North%20American%20V-Strom%20Rally%202010/VisitedStatesMap.jpg[/IMG]
cbrxxcess is offline
post #6 of 7 Old 05-20-2011, 01:24 AM
bureaucrat's Avatar
I think you might have to replace the brake line. I had 1" risers for a while and it stretched the brake hose to the point that I wasn't really comfortable with it.
The frightening thing is not dying
The frightening thing is not living
[I]T Bone Burnett[/I]
bureaucrat is offline
post #7 of 7 Old 05-20-2011, 10:40 AM Thread Starter
CHUPACABRA's Avatar
Great ideas, Thanks guys. I will try them when my parts come in.
