Gear and foot placement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-15-2011, 01:57 AM Thread Starter
I just rode my bike for the 1st time today and I don't know if its my shoes or what but I feel like I really need to force my foot underneath the gear shifter. Maybe its just the shoes, I'm wearing hiking boots at the moment. Any suggestions?
footballdan is offline
post #2 of 9 Old 05-15-2011, 02:00 AM
boots
If the boots don't allow a fairly flexible ankle movement they'll be difficult at best. Takes time to get used to the shifter too.
Bill H.
griffin800 is offline
post #3 of 9 Old 05-15-2011, 02:18 AM
Banned
When I got my bike from the dealer, the controls weren't to my liking, and when I got home I lowered both the brake and the shifter. BE careful to adjust the brake-light switch if you adjust the brake.
SittingDuck is offline
post #4 of 9 Old 05-15-2011, 08:55 AM
Originally Posted by footballdan View Post
....I really need to force my foot underneath the gear shifter.
The stock shifter height does present a challenge for large/thicker boots. The rubber topped foot peg doesn't help either.
There's a good thread on adjusting the shifter...
https://www.stromtrooper.com/maintena...so-higher.html
John
2010 Black DL650 (sold)
nhoj is offline
post #5 of 9 Old 05-15-2011, 10:52 AM
How do you do that?
Gitana is offline
post #6 of 9 Old 05-15-2011, 12:18 PM
Both levers have height adjustability built into their linkage. The rear brake light switch has a large nut to adjust its height. #29 is a typical fine adjuster. Loosen the nuts #37 and #34. One has has a left hand thread, I think it's #34. Check the thread direction. Then turning #29 will raise or lower the lever. For a coarse change if needed, remove bolt #36, take #27 off the shaft and replace it moving one spline different.
#17 is the rear brake light switch. The large nut is the adjuster for the switch.
post #7 of 9 Old 05-15-2011, 01:27 PM
I had the same issue with my Vee until I began raising the shifter a little at a time until it was right for me. I have switched boots since then with no need for further adjustment. I imagine that the typical tall toe of a hiking boot might require greater adjustment.
07 DL1000, all farkled up
mountainmeterman is offline
post #8 of 9 Old 05-16-2011, 04:01 AM Thread Starter
I'm going to adjust the gear shifter.........wish me luck. Its just to low for me. Thanks guys.
post #9 of 9 Old 05-16-2011, 08:53 AM
BillZ's Avatar
Hummm...I was thinking of moving it down to make it easier to shift while standing...
"Not all those who wander are lost." J.R.R. Tolkien
DL650AL
LIMNCS #51
Shiro Nakama Shichi #007 :beatnik:
BillZ is offline
