Where does this go? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 08-22-2006, 08:06 PM Thread Starter
I rock at logic
LucasD's Avatar
Where does this go?
While digging around my Wee I stumbled across this
connector hanging in mid air. It's hanging between
the front throttle body and the radiator. You can see
it if you look from the right side of the bike. The wire
colors are Orange with a Green stripe and Black with
a White stripe (no not the band! 8) ).
Any idea as to what this is? It doesn't appear to
have any place to connect to.
FRONT OF BIKE -------------->
2006 DL650
"We've done four already, but now we're steady and then they went one, two, three, four..."
LucasD is offline
post #2 of 5 Old 08-22-2006, 09:23 PM
It's a heated grips connector. The Suzuki brand plugs right in. It will fit a Suzuki horn connector if you want to use it to power something else. B/W is ground and O/G is hot when the ignition is on.
post #3 of 5 Old 08-22-2006, 09:35 PM Thread Starter
I rock at logic
LucasD's Avatar
Good to know.
Thanks Pat.
2006 DL650
LucasD is offline
post #4 of 5 Old 08-22-2006, 11:00 PM
You should buy a Lotto ticket today as you are lucky to see the connector. I had to dig for quite a bit to find mine.
ononewheel is offline
post #5 of 5 Old 08-24-2006, 03:50 AM
...and I just happen to have an extra one of these Suzuki horn connectors NIP if you need it (no, I'm not kidding).
Stromette
STROMETTE is offline
