V-strom for small riders? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 07-30-2006, 03:23 PM
MDStrommer
My wife loves riding pillion on my DL1000 and wants to get one for herself (DL650). Problem is, she's about a 28" inseam and has trouble touching the ground on tippy-toes on mine.
Is the six-fiddy shorter? What are all the tricks that can be used to make one shorter? Any "smaller-statured" riders here that could give us some pointers? thanks!
-Dave
post #2 of 18 Old 07-30-2006, 04:19 PM
kurt1305
With lowering links, the short seat and maybe boots with heels, she should get pretty close to flat footed.
post #3 of 18 Old 07-30-2006, 05:04 PM
Wee is shorter
According to test report I read on 650 it is 1 1/2 inches shorter than the 1000. I have 30" inseam and have no problem. She should sit on a 650 and see how it fits. With possible adjustments and thick shoes it has possibilities.
When all else fails, twist the right wrist!
50 years of riding: Sears Moped, Cushman Super Eagle, Honda Super Hawk, Honda SL350, Honda CB750, Suzuki X6 Hustler, Yamaha 250 Trials, Honda CB 900, Honda Gold Wing 1500, '07 VStrom 650
WeeVgone is offline
post #4 of 18 Old 07-30-2006, 06:28 PM
Jonnylotto's Avatar
Send a message via AIM to Jonnylotto
Re: V-strom for small riders?
-Dave
There are a lot of shorter riders on the 650, <5'8", <30" inseam. Not all of them have lowered their suspension to ride the Strom.
JonnyLotto
DL-650K5
"Honor does not need to defend itself nor does Valor need to fly a pennant to say 'I am brave'.
This is Pride mistaking itself for Virtue."
Jonnylotto is offline
post #5 of 18 Old 07-30-2006, 07:43 PM
805gregg's Avatar
I've got a 30" inseam and I ride a DL1000, I've even raised it up for more ground clearance, I don't understand why everybody is so concerned about touching the ground, I balance mine on my toes.
805gregg is offline
post #6 of 18 Old 07-30-2006, 09:16 PM
Are you being serious??????? :shock: Have a little oil or grit at a stop, while being on your toes....you'll wish you were more flat footed!
Best of luck to ya! :wink:
post #7 of 18 Old 07-30-2006, 11:52 PM
If you can't find a lowered 650 to try on, you can improvise as follows:
The KoubaLinks drop the height by 1 1/8"
The 650 seat is a little over 3/4" lower than the 1000
Total height change is 1 7/8"
A "2X4" is about 1 1/2" thick, so you could lay a 2X4 on top of a piece of 3/8" plywood on either side of your DL1000, and have her see if she can comfortably balance the bike with her feet on the boards. Obviously, you'd have to do this carefully to avoid an "oops."
Is she an experienced rider? There are some on this forum who have strong opinions on whether the Wee is appropriate for an inexperienced rider, especially if there is a height issue. If you have the time, see: https://stromtrooper.com/forum/viewtopic.php?t=5143
Tim
Former DL650K6 rider
Bunker is offline
post #8 of 18 Old 07-31-2006, 10:18 AM
805gregg's Avatar
Took the DL to Baja not going get any more gritty than that.
805gregg is offline
post #9 of 18 Old 07-31-2006, 10:20 AM
-Dave
Has she sat on an SV650? Since they share the same engine, it might be something she could consider.
Jason is offline
post #10 of 18 Old 07-31-2006, 06:18 PM
Baja riders and motocross riders usually are short...but they also almost NEVER have a need to touch the ground with both feet. :wink: The asphalt jungle is ALLOT different, as you already know!
I personally wouldn't feel comfortable, not being able to at least put down the whole front of my feet on the pavement.
