Cal Sport Fuel Injection Tuner - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 10-21-2010, 09:27 AM Thread Starter
I purchased a Heal Tech GiPro/ATRE for one of my other bikes so receive an occasional product notification from the U.S. distributer. I just received notification of a new product, an FI Tuner Pro. It just might resolve some of the DL1000 issues. Below is from the email:
" Cal-Sportbike / Blue Monkey Motorsports Inc., the exclusive USA importer for HealTech Electronics, announces the release of the all new FI Tuner Pro for fuel injected Suzuki motorcycles. FI Tuner Pro is a true map-based tuner, adjusting at 11 throttle positions in 500 RPM increments. It supports fuel addition AND subtraction (there are times subtraction is needed), and it can store 3 independent user-selectable maps. It controls all 8 injectors on an inline-4 bike.
FI Tuner Pro connects to the ECU expansion port under the seat in just a few minutes. No need to remove fuel tank or fairings. Size is about 1/3 the dimensions of competing units. Setup is straightforward due to the "Auto Cell Select" and "Immediate AFR Response to Cell Update" features. The table is color coded for easy/fast viewing. The unit can be set up manually (without dyno) if customer has an AFR gauge or AFR logger and simply wants to add fuel in small increments (never subtract fuel by guesswork).
FI Tuner Pro has simple, responsive, and efficient interface. No confusing options, no menus, everything is shown at a glance. AUTOMATIC fail-safe software AND firmware updates. Unit is USB-powered and fully USB-native.
FI Tuner Pro fits MOST Suzuki EFI models from 1997 to present. So it can be moved easily to almost any other Suzuki EFI motorcycle. While the FI Tuner Pro does not mate to a native quick shifter module, you CAN USE a stand-alone quick shifter module kit in complete harmony with this kit. It also works great with an X-TRE or GIPRO w/ATRE installed.
The FI Tuner Pro has an industry leading 5 year TRANSFERABLE warranty after an initial 30-day money back guarantee. Most others have a 1 year NON-transferable warranty. Retail is $229.99."
There was also a link with it for more information.
Cal-Sportbike Distribution ::: FI Tuner Pro (tm) by HealTech Electronics
Navigator is offline
post #2 of 2 Old 10-21-2010, 10:52 AM
I like the 15% throttle position tuneability, but I'm disliking the 500rpm increments.
uraberg is offline
