electrical problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 10-18-2010, 03:02 PM Thread Starter
Unhappy electrical problem
hi everyone new to this
i got a bit of a problem with my 2007 dl1000 my instrument cluster connector has come off the end of its cable in a little bump i had, and i don't know what colour cable goes where, please can someone help.
kevpugh is offline
post #2 of 4 Old 10-18-2010, 03:16 PM
kenneth_moore's Avatar
Can you be more specific, or post a photo?
I have the same year Vee and the factory manual (at home). I can check it for you if you can narrow it down.
Go hakafugu yourself.
kenneth_moore is offline
post #3 of 4 Old 10-18-2010, 04:10 PM Thread Starter
electric problem
hi
at the back of the clocks the plastic connector is still pluged in but the cable has been pulled out there are sixteen coloured cable ,at the back of the clocks there are two rows, top row three blank four, bottom row four blank five where the cables have come out,it would be great if someone could look at one and let me know what goes where.many thanks.
kevpugh is offline
post #4 of 4 Old 10-18-2010, 04:29 PM
I have the factory service manual by chapter in .pdf format. If you PM me your email address, I'll use sendthisfile.com to send the electrical system chapter and wiring diagrams to you.
You should be able to easily match up each wire with it's home with the wiring diagrams in the .pdfs.
