Has anyone tried these bulbs? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 10-18-2010, 01:17 PM Thread Starter
BrownMichael's Avatar
V-Strom - High Intensity Infra Red Bulb
For those who don't know, here's the deal with halogen infra-red bulbs. It is basically a normal halogen bulb with a coating applied to the quartz envelope that reflects infra-red light back onto the filament. This raises the temperature of the filament so that it puts out more light. Visible light passes through the coating so there is no color shift. If you look closely, you can just barely see a faint grayish coating on the quartz.
I put a pair of halogen infra-red bulbs in my minivan about 4 years ago and they have worked well. Normal life span, normal color, normal power consumption and somewhat brighter than standard bulbs.
The bulbs at VStroma.com only use 35 watts each, instead of 55/60, so my guess is that they probably have about the same light output as stock bulbs. The payoff would appear to be in the lower wattage. On a Strom, saving 40 watts simply by changing your headlight bulbs would be a nice thing - if there is no downside.
So, has anyone tried these bulbs in their Strom? Anyone want to try them and give us a report?
Take Care,
Mike Brown
Vancouver, WA
2011 DL650 ABS (white) Fully farkled and going strong.
2004 DL650 (blue) sold to Blair Layton for use as a project bike.
1992 Honda CB750 Nighthawk
1982 Yamaha XV920RJ
1978 Yamaha XS-500E
1968 Suzuki X6 Scrambler
You can call your bike a Wee if you like. I call mine the LightStrom!
BrownMichael is offline
post #2 of 15 Old 10-18-2010, 01:46 PM
Location: Here, there and every where but mostly in the South West
Looks pretty cool. I might have to try a set myself. If I could save a few watts for heated gear, then that would be a major plus.
DayTrippin is offline
post #3 of 15 Old 10-18-2010, 02:30 PM
Interesting technology...do you know if the round bulb shape impacts how the headlight reflector projects the light on the road?
I don't do much night riding so the impact for me would be low...it might be worth a try but the shipping to Canada is higher than the bulb price so I'll wait till I can pick some up at a local shop. In the meantime I'd appreciate hearing from anyone that tries them on their bike.
DL650A K7
StromTech is offline
post #4 of 15 Old 10-18-2010, 03:58 PM
Having never changed the bulbs out on the Vee, is it as easy as it looks? It looks like I can just pull off the connector, remove the rubber boot and pop out the bulb? Is that all there is too it? No disassembly required of fairing or other parts? I know of course not to touch the bulb.
How many watts does the Vee draw at normal cruise? Anybod know?
post #5 of 15 Old 10-18-2010, 04:10 PM
Here's info about the HIR1 (9011) and HIR2 (9012) bulbs for Toyota Supras that use the same technology:
HIR1 (9011) & HIR2 (9012)
I use the 9012 bulbs in my Volvo to replace 9006, and they are very good.
I did not know of this technology in H4 bulbs, and I'm curious about who makes them and if they're any good.
post #6 of 15 Old 10-18-2010, 04:33 PM Thread Starter
I just sent an email to the VStroma folks asking for more info. When I get something back, l'll share it with the group.
1982 Yamaha XV920RJ
1978 Yamaha XS-500E
post #7 of 15 Old 10-18-2010, 06:07 PM
And, are they dual filament bulbs for high & low beam?
post #8 of 15 Old 10-18-2010, 06:12 PM
The link in the first post to Vstroma indicates they are H4 replacements
DL650A K7
post #9 of 15 Old 10-18-2010, 07:00 PM
Yes, but...
...the vstroma people don't seem to be the most technically astute vendors.
...these are not "high intensity infra red bulbs" which would pass the infrared light. They are infrared reflective bulbs which reflect the infrared back to the filament. Big difference.
...usually a dual filament bulb is listed with the wattages for each filament, i. e., 60/55, etc. These are just listed as 35 watt.
It can't hurt to ask. As one of the laziest people I've ever known, and used to get contractors to do good work for him, said, "you get what you inspect, not what you expect."
On further review...an expanded look at the photo from vstroma shows two filaments and 35/35w listings.
post #10 of 15 Old 10-18-2010, 07:11 PM
Fyrman's Avatar
I like that, in fact, I may use it. (We've never me so we'll just say the HE'S still the laziest guy you know! )
Looking forward to more info on these bulbs as I do do a fair bit of night driving. I am impressed with the light output of the stock bulbs but then, it's the first post 80's bike I've owned in many years. That' and I'm easily impressed.
[SIGPIC][/SIGPIC][quote=Bwringer]It's a feature, not a bug.[/quote]
Fyrman is offline
