Heated gear time limitations? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 10-15-2010, 04:43 PM Thread Starter
bobosmite's Avatar
After moving from FL to VA, I have spent two Winters stuck inside because of cold weather. Time to upgrade my heated grips and get some real gear. Can I run a jacket liner and gloves continuously for hours and not worry about burning it out? Does it need cooldown time? In the past I had an issue with my electrical system and at the same time I was running heated grips for a few hours, so I can't help wonder if it causes a problem.
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
post #2 of 11 Old 10-15-2010, 04:51 PM
randyo's Avatar
I've used my heated gear for 23hours straight,never a problem
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #3 of 11 Old 10-15-2010, 05:42 PM Thread Starter
bobosmite's Avatar
Awesome! Sounds like it's going to be a nice Winter this year.
2014 Suzuki DL1000
post #4 of 11 Old 10-15-2010, 08:10 PM
Sharkey's Avatar
Send a message via Yahoo to Sharkey
Volt meter
You need to moniter your voltage if you run a heated jacket, gloves on full for any length of time, you run the chance of running your battery down to low!!!! Go ahead, ask me how I know Ive been monortoring my digital Volt meter ever since.
Sharkey is offline
post #5 of 11 Old 10-15-2010, 08:24 PM
tmcgee's Avatar
+1 Just get a volt meter and make sure the voltage stays over 12.8V. If you can't get enough heat that way, pull one of the headlight connectors to free up 55 watts.
tmcgee is offline
post #6 of 11 Old 10-15-2010, 09:03 PM
ozart's Avatar
My system drops from 14.7 to 14.5 with a 52 watt synergy vest on high.
ozart is offline
post #7 of 11 Old 10-15-2010, 09:19 PM
randyo's Avatar
my voltage used to drop down to the mid 13s as I turned my heat up, 90w First Gear, Gerbings gloves and Suzuki grips, but now with the MOSFET regulator, I never see anything other than 14.4 or 14.5 on the meter
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #8 of 11 Old 10-15-2010, 10:13 PM
ozart's Avatar
I do think the MOSFET is a worthwhile upgrade and will be doing mine someday. But yeah, the one time my cooling fan came on this summer, the voltage dropped to low 12s at idle and would not get above 13.2 at higher rpms untill the fan went off.
ozart is offline
post #9 of 11 Old 10-16-2010, 05:41 PM
Juan Tanamera's Avatar
I have never seen anything above 13.9. Hmmm...
When I run my heated gear (gloves, jacketliner, socks) I keep it above the 12.8 area too. I use one of those weather proof Datel voltmeters and it was well worth the investment.. A dual controller also helps to make adjustments to heat settings for multiple items of heated gear.
Orange Wee Member #420
Juan Tanamera is offline
post #10 of 11 Old 10-16-2010, 06:44 PM
... but now with the MOSFET regulator, I never see anything other than 14.4 or 14.5 on the meter
You upgraded only the voltage regulator and got this improvement?
Gramps is offline
