Neck Burn - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 10-15-2010, 10:12 AM Thread Starter
SWybrow's Avatar
Neck Burn
I am new to the V Strom. I got my bike about 2 1/2 weeks ago (07 DL1k) and was able to put about 600 miles on this past weekend which is a good weekend for me.
The problem I am having is that I am getting a huge burning sensation across the back of my neck and shoulders, mostly over my left shoulder.
I have installed Rox Risers for the bars which raised the bars about 1 1/2" and moved them back about 1". I also use a small back rest that I find helps me sit straighter, not so hunched over. I am 6'6" tall.
I was wondering if anyone else has experienced the same kind of issue and what they were able to do to help it. Are my bars still not high enough? I am finding now that the burning sensation happens even after a short ride.
Last thing. If someone could tell me how to insert pictures in a thread I would appreciate it.
Thanks
SWybrow is offline
post #2 of 14 Old 10-15-2010, 10:21 AM
Heavy's Avatar
Posting pictures:
https://www.stromtrooper.com/photogra...faq-howto.html
DL1000K6
Heavy is offline
post #3 of 14 Old 10-15-2010, 10:22 AM
Bahill's Avatar
Thanks
See if this might help...
https://www.stromtrooper.com/stromtro...faq-howto.html
[LEFT][/LEFT][FONT="Arial"][/FONT][FONT="Arial Black"][SIZE="4"]2012 Yamaha Super Tenere[/SIZE][/FONT]
Bahill is offline
post #4 of 14 Old 10-15-2010, 11:06 AM
Thanks
I found the V-Strom to have bars too low and too far forward. I am 6' but with a 32" inseam so tall from the seat up. The bar risers help on my Wee strom, I had to put ATV bars on the Vee because of the Scott's steering dampner. Ideally I would raise the bar and bring it to the rear even more, but I am out of brake line slack. A set of bars that angled the handgrip area more rearward would be helpfull also. I don't really get the "burn" you describe anymore, but my elbows are too straight. I will say the bar setup I have now is about perfect for riding while standing on the pegs. At 6'6" you may have to go to longer brake lines and put a taller bar on with the risers to get it where you are comfortable.
realshelby is offline
post #5 of 14 Old 10-15-2010, 12:24 PM
Dr. M's Avatar
Another factor that can contribute to the shoulder problem is helmet weight. I rode with a Scorpion EXO700 for years on my previous DL650 and now my DL1000 (same Puig windscreens, etc.)... then about a year ago I started getting lots of pain in my neck and shoulders. I had an opportunity to step up to a Shoei X-11. The helmet is lighter in weight than the Scorpion and the pain went away in about 3-4 weeks.
You might consider asking Santa for a new helmet (especially now at the end of the season when there are so many great sales going on).
Steve
2008 DL1000, Two Brothers, PCV, etc., etc.
2008 GSX1340R Hayabusa, Velocity Racing Turbo, boost controller, water injected
2002 CBR600F4i
2008 GSX-R600, Akrapovic full Ti, PCV w/AutoTune
DynoJet 250 dynamometer (just learning to use it)
Dr. M is offline
post #6 of 14 Old 10-15-2010, 02:35 PM
I wouldn't rush too much to alter things until you have owned the bike a bit longer. I suspect you are suffering from the effects of having ridden the bike for long periods but your body hasn't yet adjustered to it yet. You may also have been a bit tense at times due to the bike being new to you. May sound daft but wait and see...you will probably find you will feel more comfortable as time goes by without doing much else to the bike. It's a bit like a bike seat...some people jump on a new bike ride it for 150 miles and find the seat uncomfortable...yet within a couple of weeks your rear end adjusts to the new shape being imposed upon it and everything is fine. That why it's not usually a good idea to change the seat straight away either.
[SIZE=2][SIZE=2][I]V-Strom 1000 k8 GT - Now Gone! But 2012 Burgman 400z ABS now in service...[/I][/SIZE]
[/SIZE]
Starfleet is offline
post #7 of 14 Old 10-15-2010, 04:57 PM
ozart's Avatar
I agree with this. I suffered the same symptoms on one of my new bikes the first few long days I rode it. The symptoms gradually disappeared as my body adjusted.
ozart is offline
post #8 of 14 Old 10-15-2010, 06:49 PM
bwringer's Avatar
Very good point. The human body is surprisingly adaptable.
I've also found that many muscle aches and joint of this sort are caused by simple tension. Once you get used to riding a new bike and relax, you get a lot more comfy.
I've always told people to ride a couple thousand miles before changing stuff, and it's always worked for me.
But some things you know are wrong right away, like the hellish buffeting barn door of a windscreen that was on my Vee when I bought it.
bwringer is offline
post #9 of 14 Old 10-15-2010, 07:06 PM
LordSmoke's Avatar
Let me know if you find the answer. 6'4" I have Sargent seat, Rick's peg lowering kit, 2" Rox risers, PHys. Ther. stretching and exercises, and still the burning pain. 25k miles with the bike. Saving up for extended cables and wires (already +2 brake lines) and an additional 1 inch Rox riser block. Sometimes I wonder if I will be able to keep riding. It's the only significant discomfort I have, but it really takes the fun out of it.
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #10 of 14 Old 10-15-2010, 07:55 PM
BrownMichael's Avatar
A couple of visits to my Chiropractor before my annual long summer trip does it for me. Didn't visit a Chiropractor until two years ago, but was apprehensive about leaving on a five day ride with a tight, painful upper back. (It is mostly from work stress) He fixed me up in two visits and I did not have to go back until the next summer before my annual trip.
A good massage therapist might also be able to loosen you up.
You might also want to consider lowering your footpegs or raising your seat height. It may not help, but it is on my list of things that will effect back problems.
Mike Brown
Vancouver, WA
2011 DL650 ABS (white) Fully farkled and going strong.
2004 DL650 (blue) sold to Blair Layton for use as a project bike.
1992 Honda CB750 Nighthawk
1982 Yamaha XV920RJ
1978 Yamaha XS-500E
1968 Suzuki X6 Scrambler
You can call your bike a Wee if you like. I call mine the LightStrom!
BrownMichael is offline
