Front end wobble. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 10-12-2010, 03:57 PM Thread Starter
Front end wobble.
I am starting to ride with some sport riders. We are all similar in capabilites and I dont have any issue keeping up, I push a few of them. The issue I have had is that on exiting a corner under hard acceleration I get a wobble like the front end is washing out. Makes me nervous. Am I exceeding the capablities of the poor front end and need traxxion or something to ride at the next level or is it technique?
Thanks
Danner21
danner21 is offline
post #2 of 19 Old 10-12-2010, 04:25 PM
Do you have a fork brace?
post #3 of 19 Old 10-12-2010, 04:28 PM
lean forward a bit so you don't lift the wheel under power
uraberg is offline
post #4 of 19 Old 10-12-2010, 04:42 PM
CHIA's Avatar
LOL...ya, the 650's overwhelming power is a real tire shredder.
I would echo what greywolf asked....forkbrace?????
The other thing to have checked, is that your suspension is properly set up.
There are many variables, one is your "feel"....when the front end of washing out, you'll know it, there's no sorta/kinda in this feel.
Another consideration, "grip", ie, your hands, holding on too tight.
CHIA is offline
post #5 of 19 Old 10-12-2010, 05:22 PM
SpeedStar's Avatar
Fork Brace was a great addition for me. I agree with GreyWolf and Chia.
FARKLE your Strom with ORIGINAL HEADLIGHT MASKS, frame guards, triple-clamp guards, fork guards and tank guards. Check them out in the link below. Thanks, Devin.
https://stromtrooper.com/showthread.php?t=19554
SpeedStar is offline
post #6 of 19 Old 10-12-2010, 06:08 PM
Also check the steering bearings, and I'm assuming you keep a close check on tire pressure. Front wheel bearings good?
post #7 of 19 Old 10-12-2010, 06:16 PM
Kidder's Avatar
Like was said above, the front end is getting a little light under hard acceleration. Raise the fork tubes 10mm for a more planted front end feel. I don't have a fork brace but I hear they help a lot.
Currently Bikeless
Kidder is offline
post #8 of 19 Old 10-12-2010, 07:03 PM Thread Starter
Thanks
Cool, Fork brace and Road attacks.
danner21 is offline
post #9 of 19 Old 10-12-2010, 07:13 PM
Sit right forward as well, the rear will skate round a bit more, but the front will be a lot more planted - personally I prefer the rear wheel sliding and the front stuck down - at least compared with the alternative .
Pete
PeteW is offline
post #10 of 19 Old 10-12-2010, 07:23 PM
Might just be exceeding the capabilites of the front tire....what you have on there and the mileage?
