For Vibrating Givi Crashbar Sufferers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 10-05-2010, 10:40 AM Thread Starter
binsel's Avatar
All those quick fixes did not fix the crash-bar caused vibration on my 650. I was ready to change the crash-bar sometime this winter.
Recently I installed Happy Trails highway pegs (DualSport Plus - Suzuki VStrom DL650/1000 adventure, enduro, dual sport motorcycle parts, accessories and apparel - Happy Trails Highway Pegs) using U-bolts from HomeDepot and some rubbers in between, and the vibration is GONE
binsel is offline
post #2 of 4 Old 10-05-2010, 10:13 PM
Did you try using a bit of old bicycle tire innertube where the crashbar mounts to the frame and in front of the front cyl. bolt? Cut the innertube to size and you should silence the bars..
Doc Steve2 is offline
post #3 of 4 Old 10-05-2010, 10:19 PM Thread Starter
binsel's Avatar
Yes, I tried various types of rubbers including inner tubes. The difference was hardly noticeable. Now, it's like there is no crash-bar.
binsel is offline
post #4 of 4 Old 10-06-2010, 01:47 AM
The Givi's have a crimped fitting on the front attachement point that can become loose and allow the bars to vibrate.
When I got my set, there was a burr in the fitting and I forced it a bit too much. The result was that the fitting came lose and started rotating. A bit of welding and it's fine. The tubing is thick enough that it can take a bit of penetration.
I do NOT know how safe it is to weld them while they are on the bike, several inches from the gas tank. I wouldn't do it. Best to punch mark them, take them off and put a couple of good welds. Problem "should" be solved.
Spartan is offline
