shifter extension? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 10-01-2010, 01:12 PM Thread Starter
johnnail's Avatar
shifter extension?
I need a shifter extension for the Wee. My goofy feet stick out and I have to do the "pidgeon toe" to shift. I'm unable to find one online. Does anybody make an aftermaeket piece?
johnnail is offline
post #2 of 7 Old 10-01-2010, 01:24 PM
randyo's Avatar
since I've installed goldwing pegs, my shifting has become a bit pigeon toed as well
on my SV650, I purchased a stock shifter, took it to a local metal fabrication shop. Had them cut it in half and weld a 2" extension in the middle, plan on doing the same for my Vee
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #3 of 7 Old 10-01-2010, 03:53 PM
Yak
Yak's Avatar
Are you looking to make the rubber part that your toe goes under longer? Stick out to the side more? Never seen anything that does that.
Yak is offline
post #4 of 7 Old 10-01-2010, 06:42 PM Thread Starter
johnnail's Avatar
I believe I'll just heat and bend it.
johnnail is offline
post #5 of 7 Old 10-01-2010, 09:25 PM
dtalk's Avatar
I'm not clear on what you're after, but if you want a longer peg -- the part that your toe lifts -- why not just cut it off, drill the lever, and install a bolt with some padding? I know some guys have done that out of necessity when the shifter peg broke. You could do it pre-emptively ...
dtalk is offline
post #6 of 7 Old 10-01-2010, 10:27 PM
Ranger Gabby's Avatar
how about this??
https://www.stromtrooper.com/dl650-sp...d-shifter.html
2009 DL650 ABS with .... a basket, a bell that rings and things that make it look good. (Sold)
1976 CB550 Four... currently in about 1,000 pieces
2010 YZF-R1 LE (Sold)
1985 V30 Magna... currently in about 100 pieces
Ranger Gabby is offline
post #7 of 7 Old 10-02-2010, 08:41 AM
xgman's Avatar
A BMW R1200RT Shifter Extension will fit the Strom.
xgman is offline
