Is service intervals about the same for the 1000 as the 650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-30-2010, 09:00 PM Thread Starter
zzzzip's Avatar
I just bought an'07 1000 and it did not come with the owner's manual. I have a 650 and the owner's manual. Is service for both pretty much the same (can I just reference the 650 manual)?
Can somebody point me to a thread or source for the 1000 so I can do a proper job on plug and filter changes, etc. and it would be nice to know how to set up the shocks.
Thanks for any help.
zzzzip is offline
post #2 of 7 Old 10-01-2010, 01:48 AM
Posting a link to an online manual is against forum rules. I'd suggest an edit quickly.
post #3 of 7 Old 10-01-2010, 07:39 AM
pvwheeler's Avatar
Smile the same!
my k7 650 and my k4 1000 are identical except for tightening the exhaust bolts.
More often on the 650.
i would think the vee would be alot more likely to shake exhaust bolts loose..
2015 Wee2 EXP "Arya"
2002 DR650 SM "Tormund"
2014 CB500x (wifes)
2018 XT 250 (wifes)
pvwheeler is offline
post #4 of 7 Old 10-01-2010, 12:39 PM Thread Starter
zzzzip's Avatar
OK, another dumb question.
The V has a whirring noise when running, or at idle, that is very pronounced. Sounds like transmission area. On the other hand, the Wee has no such noise and is much more quiet.
Is that whirring normal for the V?
Also, the tank is whistling at the gas cap as it expands from the engine heat when parked. Is there a fix for this? (Did some more research and found the reason, but not the fix).
Thanks
zzzzip is offline
post #5 of 7 Old 10-01-2010, 02:12 PM
pvwheeler's Avatar
Dunno about the whistle but the whirring is normal,i figured it was because of the gears driving the cams instead of a chain on the wee...
2014 CB500x (wifes)
2018 XT 250 (wifes)
post #6 of 7 Old 10-01-2010, 02:34 PM Thread Starter
zzzzip's Avatar
Kind of what I figured too. I had a Connie for a while that sounded the same, especially cold.
Thanks for the reply.
zzzzip is offline
post #7 of 7 Old 11-01-2010, 04:22 PM Thread Starter
zzzzip's Avatar
To answer my own question about the tank whistle: found the vent line was twisted going to a canister. Got the kink out, and the problem was solved.
zzzzip is offline
