Tying down a V-Strom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 09-21-2010, 01:39 PM Thread Starter
I have heard there is a better way.
I had been using the soft Canyon Dancer straps, but they scrunch the grips. So I bought the Canyon Dancer with the hard cups, they bent the bar end caps.
I have heard there is a way to hook onto the fork under the cowling. Where exactly would I hook the straps and do I need some kind of special strap?
LittleWillie is offline
post #2 of 15 Old 09-21-2010, 01:53 PM
I hook my straps directly to my givi crash bars up front and in the back to the frames for my jesse's.
IIRC the straps can go up inside the fairing and hood to the bars close to the clamps. I haven't done this for a while and then only did it once or twice so my memory could be wrong.
DL1000K8
So what is it, am I a smart*** or a dumb***? Maybe I'm just an ***hole.
10guy is offline
post #3 of 15 Old 09-21-2010, 01:58 PM
Willie
I use soft loops around the fork leg just above the lower triple clamp. Hook the tie down into the loop left sticking out. Examples here; Heavy Duty Motorcycle Strap Kits
Rare is the good deed that goes unpunished
r
V-lust is offline
post #4 of 15 Old 09-21-2010, 02:08 PM
eye.surgeon's Avatar
Front straps to crash bars and rear straps to luggage attachment hardware is the way to go. Don't even put straps on the grips, especially the throttle side. Too many moving parts to break up there. The Givi bars make fantastic attachment points up front.
'09 Wee (sold)
2012 Ducati Multistrada 1200 S Touring
2006 BMW K1200LT
eye.surgeon is offline
post #5 of 15 Old 09-21-2010, 02:30 PM
kenneth_moore's Avatar
You can avoid compressing the suspension for tie-down. Instead you can pick parts "below" the suspension and use them. At the forks I connect on the lower tubes where the fender mounts. At the back I connect to the swingarm. If you can add a third pair on the rider pegs, all the better.
FWIW: I learned this method unpacking Harleys when I worked at a dealership. This is how they secured the bikes in their shipping crates. We got free racheting tie downs too!
Go hakafugu yourself.
kenneth_moore is offline
post #6 of 15 Old 09-21-2010, 04:06 PM
WNCRider's Avatar
I have been using soft straps just above the triple fork with easy access under the fairing. I use soft straps on the lower footpeg mounting brackets for the rear. I will have to try attaching on the lower tube and see how that works. Don't tie down on the grips, to much wiggle and stuff to break.
WNCRider is offline
post #7 of 15 Old 09-21-2010, 07:52 PM
ThunderEagle's Avatar
I always thought you were specifically SUPPOSED to compress the suspension when securing a motorcycle for transport?
When I picked up my Wee I had to trailer it home, and the guys at the dealer went up under the faring and over the tripple clamp on the forks in the front. Said that was all I would need, but went ahead and put some tie downs on the luggage rack in the rear to prevent side to side movement.
2009 DL650
Orange Wee Club Member #70
ThunderEagle is offline
post #8 of 15 Old 09-21-2010, 08:12 PM
Banned
Hindsight is always 20/20, isn't it?
You should have asked us before tying the bike down, I would have told you to never tie a bike down by the handlebars.
The bars bending can make your bike fall off the truck/trailer/platform.
The other sensible ting to do is to leave the sidestand deployed if you want, but the bike's weight should not be on it. Sidestands bend just as easily as handlebars.
Oh, while I'm on sidesatands: it is not recommended to leave the luggage packed and attached to the bike; that's going to bend the stand over time.
To answer your question, you can loop hooks over the lower triple tee.
Another thing you can do is to clamp the front wheel down if you have the equipment.
SittingDuck is offline
post #9 of 15 Old 09-21-2010, 09:59 PM
Living the Stereotype
Stromin'Nroman's Avatar
If you really want to know how to tie down a bike, perhaps you should check somewhere other than a V-Strom forum.
Talk to the real experts:
Trailering Tips - Harley Davidson Community
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #10 of 15 Old 09-22-2010, 08:50 AM
Craig Jackman's Avatar
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
