Which Beam to Cut Out? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 09-19-2010, 11:51 PM Thread Starter
ThatFixedIt's Avatar
I'm installing a headlight cutout switch as part of a relay kit from Eastern Beaver. (Fantastically well done craftsmanship and fast shipping!)
Does anyone have any thoughts or suggestions about which headlight to cut out? The kit can be wired for left or right beam cut out, and I cannot see an advantage one way or the other. Figure either it doesn't matter, or I am not looking at it in the right light. (OK, not a good pun, but best I can do this late.)
Suggestions, opinions, and reasons appreciated.
Galen
2015 DL1000
2012 BMW K1600GTL
2009 DL650 (Sold)
2009 Yamaha V-Star XVS950 (Sold)
All with the required enhancements.
ThatFixedIt is offline
post #2 of 9 Old 09-20-2010, 12:03 AM
My wifes Ninja has the right beam lighted up on low beam and both lighted on high beam. So I would cut the left beam so as not to argue with her about which is the correct one to light.
DL650A K7
StromTech is offline
post #3 of 9 Old 09-20-2010, 12:11 AM
halfast3's Avatar
I cut the right beam on mine. My thinking was that the left is closer to the center of the road and should be a bit more visible to oncoming traffic. YMMV
Rick
DL650A(K7) SOLD
'08 XT250
'12 Tiger 800ABS :mrgreen:
halfast3 is offline
post #4 of 9 Old 09-20-2010, 12:56 AM
Welfare Funder
Galen
Not trying to hijack the thread but why do you install one of these?
2K7 Wee Strom - MadStad, Givi E52, AdMoreLighting LEDS, Power Outlet, Joe Rocket Tank Bag, Cali-Sci Windscreen (Med), Lowering Links, Center Stand, Richland Fork brace
motox-dan is offline
post #5 of 9 Old 09-20-2010, 03:36 AM
K1W1's Avatar
Wee's do not have much spare power available from the alternator (the 2009's are way better than the earlier models though) so if you want to install extra electrical devices like driving lights or heated clothing one way to reclaim power is to turn one of the headlights off when not required. From memory a K7 Wee has about 125 watts spare in standard trim.
If I were doing it I would always turn the curb side light off.
K1W1 is offline
post #6 of 9 Old 09-20-2010, 06:20 AM
Voltar's Avatar
I used this same logic when installing mine. However, I don't think
it really matters which one you select.
Voltar is offline
post #7 of 9 Old 09-20-2010, 02:13 PM
Tall Man's Avatar
My view is the mirror image of yours. I cut the left (low) beam on my bike. My thinking was the the right beam is closer to the side of the road, where bipeds and quadrapeds come from. That's the side of the road that I want lit better. Oncoming traffic can still see me; otherwise, how'd I last all these years on a DR with it's single headlamp of lukewarm performance?
Also, as foggy mornings are now upon us (at least they are around here), I'm probably going to replace the left beam with a yellow H4 bulb. Having the cut switch installed will allow me to toggle this de facto fog lamp on and off as visibility conditions -- and the presence of LEOs -- require.
Irrespective of the aforementioned, I still have both high beams available when I need to light the road, or people, up.
TM
Tall Man is offline
post #8 of 9 Old 09-22-2010, 01:04 AM
Welfare Funder
Totally understand now. Thanks, makes sense to me.
post #9 of 9 Old 09-22-2010, 10:05 AM
I cut the right light (from the rider's position) off because it was easier to access. I had previously installed the servo for the Rostra CC under the left hand side plastic and that area was a bit jammed with extra wires, etc.
'12 Guzzi Stelvio NTX
'09 DL650 ABS (Sold)
Chuck in Indiana is offline
