Scott Oiler DIY Install Walkthrough - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 29 Old 09-19-2010, 02:42 AM
Banned
It kind of wicks to the other side, but my next setup is a dual nozzle type for sure. It'll keep the chain cleaner on the inboard side.
I don't really understand chains. On my old bikes, I did no maintenace at all on the chain, other than smearing them with bearing grease every so often.
When I bought the wee, I religiously applied a high quality chain lube every week, and the chain was shot after 10,000 kms. I think I got a bum chain from the factory.
My new chain (I changed the sprockets too) is 14,000 kms old and still perfect.
I don't know if I shoud credit the chain's quality ot the scottoiler, but I definitely like the peace of mind afforded by the scottoiler; I can just ride and forget about the thing, other than filling the reservoir with ATF every 15,000kms or so.
SittingDuck is offline
post #12 of 29 Old 10-03-2010, 01:21 PM
davenjai's Avatar
Why did you choose ATF SD?
davenjai is offline
post #13 of 29 Old 10-03-2010, 04:46 PM
GLHS837's Avatar
Upgrade: Scottoiler Dual Injector Kit
The Dual Injector delivers oil to both sides of your chain simultaneously and is the culmination of several years of product design and testing. This is the most accurate system in chain cleaning and lubrication. This product is an add-on to the Mark7 kits.
* Dual Injector
o Optional Accessory
o Plug & Play
o Small & Flexible
o MK7 compatible
o Blend-in black color
o Simplifies chain cleaning
o Extends your chain's life span
Price: $39.95
[IMG]http://sphotos.xx.fbcdn.net/hphotos-snc7/s320x320/420631_293299050736081_100001679667238_742639_1248852145_n.jpg[/IMG]
GLHS837 is offline
post #14 of 29 Old 10-03-2010, 07:47 PM
Banned
- The scottoil is basically ATF without the detergents.
- The scottoil I have tends to form white clumps at the bottom of the tank
post #15 of 29 Old 10-15-2010, 10:33 PM
Prime problem
This is the first time I've installed a Scottoiler since 01 on my FZ1. Can't remember any problems priming the FZ1 but after installing on the Wee, I had to blow on the inlet hose enough that I had to change shorts three times before I forced the oil down to the tip. 65 degrees F here tonight.
If I remember correctly, I just turned to prime on the FZ1 and it eventually ran out the tip.
I installed the non-touring model on the inside of the top GIVI racks as above but ran the outlet tube inside the side panels with a loop and then down the sub frame to the swing arm. The loop is below the reservoir. I'm about to run the outlet hose down the rack strut to the swing arm like the later poster. Still don't understand why the lack if prime. I checked the zip ties and none were compressing the hose. Any thoughts? Ian, Iowa
ianbh is offline
post #16 of 29 Old 10-16-2010, 07:33 PM
Banned
ianbh:
You know it's vacuum operated, right? Your engine has to be running.
post #17 of 29 Old 10-21-2010, 01:21 PM
Thumbs up Thanks much GW
Looks like the Scott is worth the work. I am starting the research now ...
fender5803 is offline
post #18 of 29 Old 10-21-2010, 02:18 PM
Obsesive compulsive chain disorder...but nice wright up anyway.:biggrinjester:
Toto is offline
post #19 of 29 Old 11-13-2010, 12:39 AM
davenjai's Avatar
Anyone ever have it draw oil up the vacuum line?
davenjai is offline
post #20 of 29 Old 11-13-2010, 02:03 AM
Banned
No, it's physically impossible for it to do that, as the vacuum (needle-lifting) and the oil-drip mechanisms are not connected in any way that oil can get from the one into the other.
I think that's a pretty dumb question actually; maybe a smarter question would have been "how does the system work? any chance of it sucking oil up the vacuum line?
The vacuum lifts up a needle that meters the oil dispensing onto the sprocket; the oil never gets into the tube that lifts the needle, and even if there were damage to its diaphragm, the vacuum tube would only suck in normal athmosphere.
