Help end an arguement... Is WD40 a good chain luge? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 70 Old 09-15-2010, 04:54 PM Thread Starter
Prime's Avatar
I know this has been talked about before here, but the search tool thingy isn't very helpful, (I really tried using it).
Is WD40 okay to lube your motorcycle chain? I say yes, friend says "no way" and would NEVER use it over long periods of time.
Thoughts?
"If everyone demanded peace instead of another television set, then there'd be peace" - John Lennon
"Every gun that is made, every warship launched, every rocket fired, signifies in the final sense, a theft,
from those who hunger and are not fed, from those who are cold and not clothed" - Dwight D. Eisenhower
Prime is offline
post #2 of 70 Old 09-15-2010, 05:00 PM
Some have used it with success. That being said, its properties are not a good match for the job requirement. It just goes to show that a poor lubricant used often can be better than a good lubricant used too little or one that attracts dirt and is not cleaned.
post #3 of 70 Old 09-15-2010, 05:06 PM
WD40 is much thinner than the chain lubricant I have applied. It might work if you apply it constantly, but it can't be ideal.
Strombolieri is offline
post #4 of 70 Old 09-15-2010, 05:09 PM
Depends how long you want your chain to last. The fact is it is damaging to the 'O' or 'X' ring seals. It is also designed to creep into very tight spots, and so will get past the roller seals and dilute the grease in the rollers. This eventually leads to a lack of roller lube grease as it leaches out over time, causing a very prematurely worn out chain.
Now some people will swear they have used it for years and haven't had any problems. That's either bull or they have been incredibly lucky or don't actually ride that much. There is plenty of information on the net showing disasters caused by WD40 being used as a chain cleaner and lube. In your Suzuki handbook for your bike it states to use only Kerosene to clean your chain. That's pretty good advise. That's all I use because it works and it's cheap, use a proprietory lube afterwards.
[SIZE=2][SIZE=2][I]V-Strom 1000 k8 GT - Now Gone! But 2012 Burgman 400z ABS now in service...[/I][/SIZE]
[/SIZE]
Starfleet is offline
post #5 of 70 Old 09-15-2010, 05:15 PM
WD40 will not damage seals or get past the O/X rings any more than kerosene will. It just is not a good lubricant for the roller to bushing interface which does not have lubricant sealed in like the bushing to pin interface does.
post #6 of 70 Old 09-15-2010, 05:23 PM
biker128pedal's Avatar
No.........
Or maybe if you spray it on every 50 miles.
Vstrom 650 ABS
'09 DR650
'07 Vulcan 900 LT
biker128pedal is offline
post #7 of 70 Old 09-15-2010, 05:35 PM
ozart's Avatar
Originally Posted by biker128pedal View Post
No.........
Gee, I replaced my OEM chain at 27,800 miles using 100% WD40 every 500 miles or so. Just think how long it would have lasted using a real chain lube.
:biggrinjester:
ozart is offline
post #8 of 70 Old 09-15-2010, 05:38 PM
jokermtb's Avatar
I'd never use WD40 as a chain lube.....I would however spray it on a chain to drive off water, but then put on some real lube.
jokermtb is offline
post #9 of 70 Old 09-15-2010, 05:49 PM
CanadianFZ6's Avatar
WD-40 is not a good lubricant anyway... WD-40 stands for "W"ater "D"isplacement and 40 is the formula version #. It was developed as a way of driving out moisture from electronics and such. I guess it is better than using nothing on your chain, but a real chain lube has to be infinitely better.
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #10 of 70 Old 09-15-2010, 05:51 PM
Godfather's Avatar
WD-40 is a solvent more than a lubricant and evaporates in a short period of time. It is great for cleaning a grungy chain, but I would personally NEVER use as a lubricant. YMMV
Flat Black 08' DL650. Lots 0' goodies
Godfather is offline
