Hand Guards - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 09-15-2010, 02:23 PM Thread Starter
mikidymac's Avatar
Hand Guards
Does any one have a line on the factory hand guards? I am looking for a set for my Wee and I don't mind the $47.99 that Onida Suzuki charges but I am not paying them $18.00 for shipping. Thanks for any help. I want to spend $50.00.
Also for the cold are the hand guards or heated grips better? I can't afford both.
mikidymac is offline
post #2 of 13 Old 09-15-2010, 02:47 PM
joe camarda's Avatar
Handguards
PM Coming your way
"I never trust my inner feelings...
Inner feelings come and go".
Leonard Cohen
joe camarda is offline
post #3 of 13 Old 09-15-2010, 02:50 PM
Godfather's Avatar
Gerbings Heated Gloves are the best to keep them fingers toasty!
Flat Black 08' DL650. Lots 0' goodies
Godfather is offline
post #4 of 13 Old 09-15-2010, 02:56 PM
I have both, heated grips are okay when it's cool. For cold you want heated gloves, there is no comparison.
Kevin
L2 DL650A The Orange Machine
K7 DL650 Hi Yo Silver R.I.P!
khager is offline
post #5 of 13 Old 09-15-2010, 05:18 PM
biker128pedal's Avatar
I have OEM had guards and heated grips. These work with winter gloves down to 40 F but below that I put o the Hippo Hands. At first I wanted heated gloves but did not want to deal with the wires or pay so much for the battery units. If you have nothing get the hand guards for the fall and then decide if you want heated gloves or grips. In some way I wish I had the gloves now and then wold get the jacket liner. I may need the jacket this winter.
PS. The gloves are easier to install. Just an outlet. See Easter Beaver. If I want to change bars the grips are epoxied on. But they are always there.
Vstrom 650 ABS
'09 DR650
'07 Vulcan 900 LT
biker128pedal is offline
post #6 of 13 Old 09-15-2010, 09:54 PM
I used BMW R1150GS hand guards on my Wee, only because I had them, and they fitted OK. They do what I want.
Not all that cold down here, and I dont ride in the real cold weather anyway.
2010 DL650 in Black
johno is offline
post #7 of 13 Old 09-20-2010, 11:02 PM
what was the end result here
I too would like a pair of these ...but dont wanan fork out gazillions
motopaul is offline
post #8 of 13 Old 09-21-2010, 09:04 AM
Craig Jackman's Avatar
No comparison. Hand guards look great but don't really keep your hands warm. They are really there to keep branches and brush off your knuckles. I have Oxford heated grips (the wrap on style, not the grip replacement style). These really keep your hands warm, really only useable below 45 or 50 degrees. I've had a couple of friends with heated gloves ... and they both wound up with huge blistering burns on the backs of their hands. If you get heated gloves, you absolutely must have a heat controller with them, otherwise you can't pull over fast enough to unplug them when they get too hot. With heated grips, you can move your hands around on the heating elements, plus they will at least have an on/off switch, so it's hard to burn your hands.
'03 DL1000 - "The Vee"
Mod list - Oxford heated overgrips. Garmin GPS w/Aquabox RAM mount. Mirror extenders. Givi V35 saddlebags, engine guards, and Kappa top box. Adventure Tech fork brace, wheel spacer, sidestand foot, and peg lowering kit. Gafler braided front brake & clutch lines. K&N air filter. Pyramid Fenda Extenda. GO Cruise throttle lock. Touratech folding shift lever. Rad guard. GSXR 4 piston brakes with SV Racing brackets. Yosh timing cover. SW Motech center stand and crossbar. Eastern Beaver headlight relay. 12 O'Clock Labs Speedo DRD. Werks clutch basket. Corbin seat.
Craig Jackman is offline
post #9 of 13 Old 09-21-2010, 09:22 AM
+1
I run the Tourmaster Synergy gloves off of the battery. The gloves have a 3 position heat controller (low, medium, high, plus it can be turned completely off). I really love them! Thinking of getting a pant liner and a jacket liner for this winter.
Flat black DL650A '08
New_on_Strom is offline
post #10 of 13 Old 09-21-2010, 10:41 AM
Banned
I got mine from the dealer when they were doing my tires/chain and service; they had one set left over that they had ordered for another customer. I took them and installed them myself. beleive I paid 65$; installation was a matter of minutes.
SittingDuck is offline
