Shifter adjustment - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 13 Old 09-12-2010, 11:28 AM Thread Starter
Shifter adjustment
I would like to raise the shifter a little to ease getting my new boots under it. I have searched the manual for instructions but I can't find a damn thing. Can you guys help?
How does the shift lever get adjusted for height?
Thanks.
YellowHat is offline
post #2 of 13 Old 09-12-2010, 12:31 PM
There are some differences between models but the procedure is the same so I'll use this example. Loosen the lock nuts at #34 and #37. Check the threads because one of those nuts has a left hand thread. It turns the opposite direction of a typical nut to loosen. Once loose, turn the adjuster #29 to change the pedal height. Then tighten the nuts.
post #3 of 13 Old 09-12-2010, 12:49 PM
Shifter adjustment
If I remember correctly the bottom nut #34 is the left hand thread nut.
AMA Life Member
2009 Orange Wee RIP 10-7-2010
Past rides......
3 BMW's
2 Bultaco's
2 Ducati's
6 Honda's
2 Kawasaki's
6 Suzuki's
1 Triumph
Ziggy is offline
post #4 of 13 Old 09-12-2010, 12:52 PM
Banned
I don't know if the dl1k has that mechanism... If not, just move the shifter up or down one spline at the shaft that commes out of thr transmission.
SittingDuck is offline
post #5 of 13 Old 09-12-2010, 12:55 PM
It is on the 650. I don't know about the 1000.
post #6 of 13 Old 09-12-2010, 03:51 PM Thread Starter
The shaft does have the lock nuts on the 1K, I didn't realize I needed to rotate the rod,
thanks
post #7 of 13 Old 09-12-2010, 04:54 PM
Scarlett Harlot's Avatar
I adjusted mine earlier this summer for my new boots. Just look at the threads and it's easy to see which is the left twist. A little adjustment goes a long way. I initially went a full turn. Then had to back it off by 1/4. I may back it up again by another 1/4 as my boot has broken in. A dab of white-out makes a good reference mark.
'05 GL1800A-The Banana Hammock
Target fixator extraordinaire.
Never underestimate the power of stupid people in large groups. ― George Carlin
Make the world safe for stupid people and you will end up with a world full of stupid people.
Scarlett Harlot is offline
post #8 of 13 Old 02-08-2014, 03:36 PM
kiwi_outdoors's Avatar
left vs right thread
no need to remember that stuff
just remember this, on the <= 2011 Wee
with 10mm combination wrench on either top or bottom jam nut, and free end of wrench facing front of bike, push wrench toward engine to loosen the nut(s)
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #9 of 13 Old 09-21-2014, 08:55 PM
mowcowbell's Avatar
I know this is an old thread, but I found it very helpful to know one of the jamb nuts on the fine adjustment was a left hand thread. I had the coarse adjustment done easily, but the fine adjustment was the problem until I read this. Thanks guys!
mowcowbell is offline
post #10 of 13 Old 06-22-2015, 10:38 AM
Same goes here. Old but really helpful.
Goran69 is offline
