installing skidplate - stuck at the sidestand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 09-07-2010, 11:02 PM Thread Starter
hi,
I got a small problem. I'm trying to install a SW Mototech skidplate and I can't loosen the sidestand bolts for the love of it. It's just not working.
So what are your tricks to loosen them? I heard that this is quite common and you need excessive force...
berlinguyinca is offline
post #2 of 21 Old 09-07-2010, 11:27 PM
swingset's Avatar
Send a message via Yahoo to swingset
Big breaker bar + heat.
Really strong impact wrench.
That's all I got.
Never met a dog I didn't like, a machine I couldn't break, or a woman I couldn't tick off.
swingset is offline
post #3 of 21 Old 09-07-2010, 11:28 PM
Willdiesoon's Avatar
I wrapped my wrench in a cloth and "tapped" it with a hammer.
09 DL650
[URL=http://www.fuelly.com/driver/Willdiesoon/dl650][IMG]http://mefi.us/images/fuelly/smallsig-metric/59792.png[/IMG][/URL]
Willdiesoon is offline
post #4 of 21 Old 09-07-2010, 11:48 PM Thread Starter
That's all I got.
no space for an impact wrench since I got a center stand and have no impact wrench anyway
post #5 of 21 Old 09-07-2010, 11:49 PM Thread Starter
tried this (wooden mallet) , no go. It's stuck...
post #6 of 21 Old 09-08-2010, 12:33 AM
wingnut11's Avatar
pipe
find a long pipe that fits over the end of your wrench.
wingnut11 is offline
post #7 of 21 Old 09-08-2010, 12:43 AM
Yak
Yak's Avatar
Use a propane torch or a heat gun to heat up the bolts. There should be no need to use a breaker bar or a hammer! Once the factory locktite is sufficiently warmed up it should come undone with the use of a regular wrench. That's all I needed to install my skid plate.
Tip - tie your centre stand to the front wheel to prevent it from folding as you apply torque.
Yak is offline
post #8 of 21 Old 09-08-2010, 01:17 AM
Post I used a big electric impact..
240 ft/lbs capacity I think. Heat may help, that Jap loctite is strong stuff. I used a universal joint made especially for impact guns-6 point sockets. It was a bear. That bike was killed by a car and I will have to do it again eventually as money allows. Your local auto parts store may rent tools, the one here does. If not, try heat(consider the switch) and 6 point socket with a breaker. A second set of hands to keep the socket on might help. I have a cheater pipe about 6 feet long, but a 2nd set of hands is a must with that. Good luck.
hoffy is offline
post #9 of 21 Old 09-08-2010, 02:07 AM Thread Starter
great tip about tieing the front wheel.
I'm afraid about using a torch, since I heard it weakens the steel and only want todo this as last resort.
post #10 of 21 Old 09-08-2010, 06:26 AM
Voltar's Avatar
I think you may be at the last resort stage, but that's okay. You are not going to heat the metal hot enough to 'glow' it. Just get a pencil torch and put it on the bolt. The goal is to flow the Locktite, not get the metal to a bendy state.
One thing you could try first.... Go for a long ride; maybe an hour or so, the motor may transfer enough heat into the bolt to soften the Locktite some.
Let us know how it works out.
Voltar is offline
