Hand guard compatibility question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-06-2010, 08:27 PM Thread Starter
lmaso92122's Avatar
Can the oem suzuki handguards be used on both the wee and the vee?
lmaso92122 is offline
post #2 of 7 Old 09-06-2010, 08:46 PM
They sure can.
BeemerSailor is offline
post #3 of 7 Old 09-06-2010, 09:10 PM
The Vee comes with handguards standard. The Wee has a optional kit available. The right side will fit both bikes although later model guards have a small cutout where the throttle cables go on 2007 and later Wees. The left side is different as the Vee has a hydraulic clutch and the Wee has a cable. They won't interchange.
post #4 of 7 Old 09-06-2010, 10:07 PM
Greywolf -
I assume you're right (and that I gave incorrect info). I have a 650, and I bought my handguards from Oneida Suzuki. I knew when I bought them that they did not clearly differentiate the two on their web site, so I went and checked it out. The wording in the parts description is less than clear (downright ambiguous), leading me to believe they were the same.
post #5 of 7 Old 09-06-2010, 11:00 PM
I ordered the hand guards in '07 shortly after buying my new Wee. The dealer said that they would only fit the Vee, but I went ahead based on what I read in this forum.
The guards installed with no problems and no modifications. The instructions were awful, but the installation was not difficult.
George Johnson is offline
post #6 of 7 Old 09-06-2010, 11:03 PM
The only handguard kit is for the Wee. The Vee comes with it in stock configuration.
post #7 of 7 Old 09-07-2010, 04:14 AM
I mounted a set of Suzuki handguards on my KLR650--the right side was almost a bolt-on, the left side I made a small bracket to position the guard out to match the right side. My KLR already had bar-end weights which made the guards real easy to install. Be creative, these handguards will fit most bikes if you figure out what is needed for each application.
biggyfries is offline
