Didn't want to start today - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-19-2006, 08:22 PM Thread Starter
I tried to start the Strom today and it didn't want to go. It just cranked over great but no fire. I tried this three times for about 15 seconds each. On the fourth try I blipped the throttle a tad and it fired right up and ran for the morning commute just fine and for the return trip also. Being fuel injected I didn't think blipping the throttle would be necessary.
Any ideas? Bike was started two days before without a problem. Probably nothing to worry about?
ononewheel is offline
post #2 of 4 Old 07-19-2006, 09:22 PM
I wouldn't worry about it. If the same thing happens again and frequently, you got a problem. Could be a one time thing, something to do with position of the planets and stars. Ride on.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 4 Old 07-19-2006, 10:12 PM
Zero throttle is the norm. If the engine turns over and doesn't start for some reason though or if a lot of vapor gets into the system on a hot day, the excess gas needs more air to get the mixture right. Opening the throttle will do that.
post #4 of 4 Old 07-20-2006, 03:21 AM
Re: Didn't want to start today
[quote="ononewheel"]I tried to start the Strom today and it didn't want to go. It just cranked over great but no fire. I tried this three times for about 15 seconds each. On the fourth try I blipped the throttle a tad and it fired right up
Mine did that recently. I washed it, parked in the garage where it sat for 3 days. When I went for a ride it cranked but no fire. On the second try I opened the throttle and it fired right up.
I attributed the problem to water in the switchgear. But who knows. Probably is the tipover switch or some other sensor.
Mountaintime05 is offline
