Secondary butterfly removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-19-2006, 01:26 AM Thread Starter
Have been reading up on this lately and figured I will go ahead and do it since it's free and all. Does anyone have any pics of what exactly to remove and maybe hints and tips to help make the project go smoother? I have seen the step by step instructions but haven't been able to find any pics. Will I need to remove the crash bars (Givi)? Thanks.
2006 dl1000- grey
"A man is a success if he gets up in the morning and he gets to bed at night, and in between he does what he wants to." - Bob Dylan
"Happiness is nothing more than good health and a bad memory." -Albert Schweitzer
"What we have to learn to do, we learn by doing."- Aristotle
bigtallguy is offline
post #2 of 8 Old 07-19-2006, 08:36 AM
Re: Secondary butterfly removal
It will make perfect sense to you, once you pull the air filter out, and look in there. If you have a magnetic tip phillips head, or any type of magnet at all, it will be very helpful to attract the tiny screws. Push down on the butterfly so it is closed, take your time and use some pretty good down force when you start to take screw out. They have really soft heads, try not to strip them out. Once the screws are out, the butterflies need to be pulled out. They are actually between the groove of the actuating rod, and need to be slid out. Trust me.....this will all make sense once you start to do it. VERY SIMPLE and yields awesome results. :wink:
Big B is online now
post #3 of 8 Old 07-19-2006, 11:00 AM
What is the purpose of the secondaries anyway? How does elevation affect the removal of these? I take most if not all remove them then?
MIstrom is offline
post #4 of 8 Old 07-19-2006, 05:01 PM
Warren's Avatar
Theoretically, the secondaries restrict airflow at lower RPM's to smooth throttle transition and avoid jerkiness
[B]-- Warren in San Diego --
-- 2013 KLR 650 --[/B]
-- [URL="http://www.klr650.net/forums/showthread.php?t=47348"][COLOR=blue]Click Here For My Free KLR Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
-- [URL="http://www.vstrom.info/Smf/index.php/topic,10863.0.html"][COLOR=blue]Click Here For My Free V-Strom Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
Warren is offline
post #5 of 8 Old 07-19-2006, 05:40 PM
And removal awakens the sleeping giant lurking in the DL1K motor!
xrmattaz is offline
post #6 of 8 Old 07-19-2006, 11:19 PM
MDStrommer
I'd like to read more about this. Can anyone expand on why this is a good thing? Any downside? I take it this will kill my warranty.
post #7 of 8 Old 07-20-2006, 12:29 AM
+1
Tattooed is offline
post #8 of 8 Old 07-20-2006, 01:35 AM
About killing the warranty-
If there ever was a problem that was serious or costly enough I would just spend 30 mins. and reinstall them if I thought there was any chance they might inspect inside the airbox.
I can't really expand on the exact use. I took mine out after maybe 1000 miles and the two things that changed for me were-
The low end power. Not tons more but rather a slight amount, but the power came on much quicker. For me the throttle at just above idle is more like an on-off switch. Jerky to some but I like it.
I also think the top end was more powerful too. Again not tons more but a noticeable difference.
There might also be a bit more noise after taking the secondaries out too. Others will correct me if I am wrong.
ononewheel is offline
