Do I need Pro-Taper mounts for Pro-Taper bar? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 06-11-2010, 12:02 PM Thread Starter
GLHS837's Avatar
Or will the stock mounts work? Pro Taper SE Raptor bend.
[IMG]http://sphotos.xx.fbcdn.net/hphotos-snc7/s320x320/420631_293299050736081_100001679667238_742639_1248852145_n.jpg[/IMG]
GLHS837 is offline
post #2 of 8 Old 06-11-2010, 02:56 PM
FireDog45's Avatar
The SE stands for seven eighths, the diameter of the bar. They will bolt right up but you will need to account for the cables. Too much up and back may make things a little tight.
Steve
09 GSA
Gone but not forgotten:
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
FireDog45 is offline
post #3 of 8 Old 06-11-2010, 03:16 PM Thread Starter
GLHS837's Avatar
Thanks. I was reading GWs post where it wasn't quite if he used the PT mounts because he wanted or because he had to.
GLHS837 is offline
post #4 of 8 Old 06-11-2010, 06:05 PM
KZDon's Avatar
Slight thread hijack - I understand the SE raptor bend are a little higher and farther back than stock. Any recommendations for which pro taper model is good for a little lower and farther forward (ie. less bent)?
KZDon is offline
post #5 of 8 Old 06-11-2010, 06:13 PM Thread Starter
GLHS837's Avatar
I think thats the ATV Mids, but check Grey Wolfs post about the perfect handlebar to be sure. Search term "Raptor".
GLHS837 is offline
post #6 of 8 Old 06-11-2010, 06:19 PM
Cat Herder
LowAndSilent's Avatar
Be careful there. Don't think (like me, stupidly) that "Mid" means it'll be shorter than "HI" bars. On some brands, the "HI" are shorter than the "Mids". Also, there are differences between ATV and other brands. Both can be marked "Mid" or "HI" but will have totally different characteristics. Be sure to look at height, rake, etc before purchasing.
'09 VStrom DL650A - Sold.
'04 Suzuki Burgman 400 - The wifes
'08 FJR1300AE - Miss Chievous.
WWGWD?
LowAndSilent is offline
post #7 of 8 Old 06-11-2010, 06:21 PM
Cat Herder
Also...can you mentioned what bike you have, or update your profile. If you have an ABS-equipped bike you'll definitely need to upgrade your brake lines.
WWGWD?
post #8 of 8 Old 06-11-2010, 07:18 PM Thread Starter
GLHS837's Avatar
https://stromtrooper.com/showthread.p...hlight=perfect
Heres what I was looking at. So, with the Raptors, and ABS's brake line wont work with the stock mount? Warhammer (it was his thread, not GWs, whoops) said they are the same height as stock, just wider and with less pullback. Given that, I should be fine, correct?
"The Raptor bars, when mounted the way I did it, are about the same height as stock, just wider and with less sweep."
As for the Mids, I wasnt comparing them to the Highs, just the Raptors, as seen in the lined thread. And those were all ProTapers, as he asked about.
GLHS837 is offline
