Brake Light Issue? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-27-2010, 01:05 PM Thread Starter
Brake Light Issue?
I just purchased a 2004 DL650 and noticed the brake light stays on constantly. If I use the front brake, there is no change. But if I use the rear brake, it turns off? I'm thinking there is something wrong with the rear brake switch? Any ideas?
Thanks,
Mark
mdwilli is offline
post #2 of 12 Old 05-27-2010, 01:08 PM
BubbaGee's Avatar
Send a message via MSN to BubbaGee
Sounds like the wires aren't connected correctly. Check the wiring diagram for the foot switch to see if they are correct.
Bubba
BubbaGee
2006 DL1000 in red.
"What doesn't kill you only makes you stronger."
BubbaGee is offline
post #3 of 12 Old 05-27-2010, 01:25 PM
BubbaGee's Avatar
Did a quick look at some microfiche online and it looks like it would be next to impossible to miswire the switch. I'm wondering if the previous owner had attempted to install a flash module to the tail light and managed to miswire that. Have you looked under the seat near the tail section to see if there are any extra modules installed?
Bubba
BubbaGee
2006 DL1000 in red.
BubbaGee is offline
post #4 of 12 Old 05-27-2010, 02:00 PM Thread Starter
No, the bike is completely stock.
mdwilli is offline
post #5 of 12 Old 05-27-2010, 02:09 PM
SCraig's Avatar
Disconnect the wires from the rear brake switch. When you touch them together the brake light should come on. When they are apart the brake light should be off. If that works properly you have a bad switch. I don't have the schematic in front of me but assuming that the brake light switch is normally open that should work.
Scott Craig - Nashville, TN
SCraig is offline
post #6 of 12 Old 05-27-2010, 04:03 PM
Try moving the rod at the bottom of the switch up and down. The spring connection will allow it. See if you can get the brake light to go out by pushing up on the rod. If you can, an adjustment to the switch height should handle the problem.
post #7 of 12 Old 05-27-2010, 04:47 PM
ozart's Avatar
The symptoms suggest the foot switch is stuck closed. But it's odd that pressing the brake pedal deactivates the light. According to my schematic, both switches are normally open.
If your hearing isn't too bad, you can hear the switches working. They will "click" both closing and opening.
ozart is offline
post #8 of 12 Old 05-27-2010, 05:00 PM
I think the rear brake switch is a wiper. I've never heard it click and over travel may be possible.
post #9 of 12 Old 05-28-2010, 11:12 PM Thread Starter
Thanks for all the responses! The switch height was too high, causing it to be engaged all the time. I discovered if you pull the switch too far, it causes the switch to disengage. So, that's why my brake light would go off when I stepped on the rear brake.
mdwilli is offline
post #10 of 12 Old 05-29-2010, 12:25 AM
Alpster87's Avatar
brake switch
Ouch! Graywolf one Ozart well.... Not ..... common for brake switches to go on and then off again especilly Suzuki ...
Sometimes making a wrong turn just makes the ride that much better ,,, go an extra mile it`s not so crowded there!
Alpster87 is offline
