Instrument panel pieces separating? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 05-24-2010, 01:42 PM Thread Starter
bigboy292000's Avatar
I noticed that my instrument panel plastic pieces started separating somehow - not sure what that is about? There is a noticable gap there now; this can't be good for rainy days?
If I push on the driver-side a bit, the gap closes, like so:
Any ideas why that happened and how to fix it?
My theory is that a plastic latch that might be in there (above the instrument LED screen on the first photo, in the gap) broke because of vibrations, possibly caused by my homemade windscreen brakets which raised my windscreen quite a bit. It's weird though because even though I raised the screen that way - the force of the wind still pushes the whole thing in the same direction as when the screen is stock?
Is there a plastic latch in the middle there? I never took the instrument panel apart...
09 WABS w. some farkles & teeth
[URL="https://www.stromtrooper.com/showthread.php?t=35638&page=3"]Strom Squadron Member #5[/URL]
bigboy292000 is offline
post #2 of 8 Old 05-24-2010, 02:03 PM
ozart's Avatar
Could be heat warpage. Does your bike sit in the sun alot?
ozart is offline
post #3 of 8 Old 05-24-2010, 02:19 PM
firepit1x's Avatar
Mine
My 2003 looks the same and I contributed it to heat....in fact, my dash got so hot one day....you can still see my thumb imprint and my fingerprint from where I touched it....and cursed. I had no idea how hot it was until it was too late. I try to never face my windscreen into the sun when I do have to park outside.
2003 V-Strom DL1000
[B]81,000[/B] miles and counting. "Motion Camouflage" Kills, [B][COLOR="Red"]BE SEEN[/COLOR][/B] or be a victim! [URL="http://www.network.mag-uk.org/smidsy/How%20Close%20is%20Too%20Close.pdf"]Click Here for more info.[/URL]
"The V Strom....you define it, it doesn't define you"
Loud Pipes kill OUR Rights...so PIPE down!
firepit1x is offline
post #4 of 8 Old 05-24-2010, 02:20 PM
Mine does about the same thing. Don't worry about it. The plastic rivets in the corners and the plastic spears into rubber grommets are the only connections in the front. Facing a windscreen, especially a Givi, away from the sun so the reflection focuses on the dash is what brings the heat up.
post #5 of 8 Old 05-24-2010, 04:06 PM Thread Starter
Cool, thanks guys...
Nope, my bike does not sit in the sun a lot; I hear that Givi screen can focus the light to that part of the "dash" and it is I guess possible that my raised stocker does it too.
So - basically it sounds like this is not a possible electical issue due to water getting in there? I mean it does not look like a well sealed area to begin with - but I guess that was my primary reason for asking.
post #6 of 8 Old 05-25-2010, 05:51 AM
My K8 650 has a worse gap and I've got the short Suzuki Euro screen, haven't had any water problems with it yet even after washing the bike. I'm just putting it down to poor Suzuki build quality.
08 DL650
76 Guzzi Lemans
79 Guzzi Lemans
76 Benelli 750
79 Kawasaki Z650
98 BMW F650
Doc59 is offline
post #7 of 8 Old 05-25-2010, 09:44 AM
Put a Pat Walsh dash on and the area will be out of sight. It will also solve the sun problem on the plastic. Face away from the sun with a Givi screen, and it will fry hamburgers for dinner.
post #8 of 8 Old 05-25-2010, 12:15 PM
CHIA's Avatar
I have a similar gap on my 09....just noticed it over the winter, probably always been there.
CHIA is offline
