Better to run my tailbox or my panniers? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 05-17-2010, 11:53 AM Thread Starter
eye.surgeon's Avatar
Most of us have seen that hard luggage can significantly impact mileage. I have a Givi V46 tailbox and E21 panniers. Most of my rides are day rides and I only need one, not both. I'm wondering which penalizes my fuel economy the most. The E21 panniers get a lot of bugs on the front and the tail box gets none so I am assuming the tail box is catching less wind and thus is causing less aerodynamic drag. Is this correct?
Also, I assume there is a handling penalty with the tailbox vs panniers because the weight is higher up. Correct?
'09 Wee (sold)
2012 Ducati Multistrada 1200 S Touring
2006 BMW K1200LT
eye.surgeon is offline
post #2 of 17 Old 05-17-2010, 11:56 AM
SCraig's Avatar
Fuel mileage? On a 650? Even if one or the other cost 5 mpg that's less than a penny a mile. Just ride with whichever you want.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 17 Old 05-17-2010, 12:15 PM
honest bob's Avatar
What SCraig said You may want to consider the extra protection paniers give in a fall. Just sayin. You should not have enough weight in the tail box to make any diff. Riding with a passenger hardly affects my 650.
honest bob is offline
post #4 of 17 Old 05-17-2010, 12:21 PM
A top box is the worst place to add much weight. It is farther away from the center of mass than any alternative. Tank panniers, a tank bag and low and forward in the side cases are better for weight distribution.
post #5 of 17 Old 05-17-2010, 12:23 PM
ockerstrom's Avatar
As he said
Top box gives a higher centre of gravity when loaded and you may also feel air blowing against your back due to the vortex effect created between your body and the box [this can also create drag which is why trucks have roof spoilers to deflect air upwards to eliminate or reduce the vortex].
Panniers may be wider if lane filtering at traffic lights [but I think the E21's are no wider than the handlebars], also they won't hold your helmet[s] while you are away from the bike.
I put my stuff in a backpack then in my V46 top box for day rides, that way if I need to pick stuff up during the ride or on the way home I can put the pack on my back and fill up the top box for extra capacity if needed.
Personally I don't notice the change in the centre of gravity with the top box loaded but then I don't ride at ten/tenths that often.
Also my Wee fully loaded with top box-panniers and tent/camping gear bag still only weighs in around the same as my previous BMW R1150GS did unladen.
Actually there seems to be very little difference in the handling characteristics whether laden or unladen.
Acceleration and braking are the most noticable differences I have found, the same applies running two up.
Ock. in Oz
I ride naked and unafraid.
Windsor (near enough)
NSW
Australia
ockerstrom is offline
post #6 of 17 Old 05-17-2010, 12:31 PM Thread Starter
I'm not worried about the cost I'm worried about the range. One of the reasons I bought the wee was the range, here in the mountains of California it's not hard to go 200 miles between fillups. Hard bags often cut much more than 5 MPG...if you look at the big aluminum panniers, they can cut your mileage by a good 25%.
'09 Wee (sold)
2006 BMW K1200LT
post #7 of 17 Old 05-17-2010, 12:54 PM
TheTwins's Avatar
E21 sidecases totally....best place for mass....low and split side to side. I try to locate as much mass as I can, as low as I can. I've even gone to the extent to wrap and zip-tie my tire levers to the subframe.
While I do have an E52 topcase, IF it gets used, I ride with it empty and use it to stow my riding gear when I arrive. Too much weight up there makes for an unsettling ride.
TheTwins is offline
post #8 of 17 Old 05-17-2010, 01:00 PM
tmcgee's Avatar
I agree that the fuel hit can be pretty heavy, but the biggest problem with poor mileage has to do with your right wrist.
tmcgee is offline
post #9 of 17 Old 05-17-2010, 01:19 PM
randyo's Avatar
I dunno, maybe its cause I have fat thighs that deflect the wind first, or maybe the Vee doesn't take the milage hit that the Wee does
I haven't seen any difference in fuel economy with my side cases on or off, nor have I seen bugs on them
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #10 of 17 Old 05-17-2010, 01:23 PM
SCraig's Avatar
The Givi E360's I run on my VFR cut mileage exactly zero the best I can tell. I've never noticed any difference whatsoever with them on or off (unless they are loaded to the stretching point). I've also never noticed any difference on my V-Strom with a tail bag and/or side bags or a DL1000 with tail bag and/or side bags. If those aluminum cans are cutting 25% off the fuel mileage then someone is loading them with concrete blocks.
My advice, if you are that concerned about distances, is to carry a gallon of gas in one of them.
SCraig is offline
