Chain's Getting Kinky. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-15-2010, 01:40 AM Thread Starter
Boy talks too much....
slowoldfart's Avatar
Is this doing any damage other than looking ugly? I'm at about 20k and the sprockets look ok, I'm really not sure what causes this. I lube the chain often and dont spare the stuff. I'm just concerned that it may be doing harm I cant see. Any constructive input welcome.
SOF
slowoldfart is offline
post #2 of 7 Old 05-15-2010, 02:13 AM
eye.surgeon's Avatar
20k is typical for the lifespan of a chain on the Strom. If it's kinked you need to change it.
'09 Wee (sold)
2012 Ducati Multistrada 1200 S Touring
2006 BMW K1200LT
eye.surgeon is offline
post #3 of 7 Old 05-15-2010, 05:55 AM
Correct. The links just wear out. It's a consumable item that has to be replaced periodically. I envy your 20K on the chain, I only got 13K or so on my OEM chain, before it started kinking and stretching. I attributed that to keeping it too tight. Now I'm running my new chain slightly looser.
willtill is offline
post #4 of 7 Old 05-15-2010, 01:48 PM
ozart's Avatar
I'd give it a really good cleaning as it's possible it could just be gunked up. If that doesn't help, I'd look at replacing it ASAP.
Are the kinked links real stiff, or do they easily straighten by hand?
A kinked chain should greatly accelerate the wear on both itself and the sprockets. It's probably noisy as hell. And I'd be leary of it getting too loose and riding up on the sprockets.
ozart is offline
post #5 of 7 Old 05-15-2010, 02:02 PM
enumclaw's Avatar
At 20k I'd bet that even though your sprockets look okay, you'll be surprised to see how much they've worn when you get them up close. Assuming you haven't replaced just the sprockets somewhere along the way, of course. I replaced everything at just over 20k, as the chain was getting sticky also, even though I am "pretty good" about maintenance. The front sprocket clearly had the shark fin thing developing at the time, but the rear looked just fine from the side. It was when I looked closely at the rear sprocket "on end" I was surprised to see the side to side wear was very evident.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400 | FJR
enumclaw is offline
post #6 of 7 Old 05-16-2010, 07:46 PM
bwringer's Avatar
New chain and sprockets are needed ASAP. 20,000 miles is pretty damn good.
Talk to Blair at SVracing. He'll fix ya up.
bwringer is offline
post #7 of 7 Old 05-16-2010, 07:51 PM
PhotoBiker's Avatar
As the others have said, replace this fast.
Have you measured the links to see if they might still be within spec?
I don't have the manual in front of me, aside from the length, I believe there is an acceptable number of stuck links. I think two or three is the max.
If your chain goes while riding, you'll be lucky if you only loose the chain and not take out part of the engine casing along the way.
-=Glen=-
(n1xf)
'10 R1200GS
'02 DL1000
'06 KLX250S
Check out my [URL="http://www.pbase.com/gsansoucie"]Photo A Day Gallery[/URL] or my [URL="http://www.flickr.com/photos/gsansoucie/"]Flickr Photostream[/URL]
PhotoBiker is offline
