SW-Motech Evo rack question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-10-2010, 01:02 PM Thread Starter
Question SW-Motech Evo rack question
This may seem like an odd question, I want to know if the spools on the rack work with the adapter plates to allow the bags to be removed but leave the racks on the bike. I have seem many videos of removing the racks, but none of just removing the bags.
I plan on buying seahorse cases, I would assume I need the Pelican adapter plates.
Thanks,
Adam
AdamThe3rd is offline
post #2 of 6 Old 05-10-2010, 01:59 PM
WildWildIp's Avatar
I have this rack and pelican cases. The cases are bolted directly to the rack. I do not know if you need that adapter or not. You should call up the retailer.
"I see so many low mileage used bikes for sale with tons of $$ burnt on farkles...this forum needs a farkle captain. In order to get a bash plate you have to post a pic of your Wee on a trail where you would need one. The farkle captain would then approve that trooper to buy a bash plate because they earned it" -Timshel!
WildWildIp is offline
post #3 of 6 Old 05-10-2010, 02:38 PM
rack
I agree. . .I use cases (Pelican-1550s) bolted directly to the removable motech rack. . .works fine. . .there are adaptors available to have the cases removable as well, but I never felt the need--but each to their own.
sd2ftl is offline
post #4 of 6 Old 05-10-2010, 03:01 PM Thread Starter
I dont know if I am going to buy the adapters or not, it was more or less a question of what are their function.
I also find it kinda crazy the pelican adapters are $165, while all the others are around $50
post #5 of 6 Old 05-10-2010, 04:14 PM
The spools you see in that picture are a part of one of the adapter kits. Those kits allow quick release of the case from the rack.
[URL="http://www.steelhorseraiders.com/jasons-bike/"]2009 DL650[/URL]
jasonslay is offline
post #6 of 6 Old 05-10-2010, 06:06 PM Thread Starter
Thanks! That what I assumed but I wanted to check
