How to Remove Scratches From Heat Shields - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-10-2010, 12:18 PM Thread Starter
I have a 2008 Vee with the aluminum alloy heat shields. After removing my soft bags I noticed some small black marks (scratches) in the metal. I thought I could just take some fine steel wool and buff them out, however this seemed to make matters worse.
Any way to remove these marks without having to paint the heat shields?
I did do a search, however everytime you use the word shield you end up with all of the windshield posts.
ghostrider66 is offline
post #2 of 3 Old 05-10-2010, 12:21 PM
dailystromfix's Avatar
easy fix!
Just put the bags bag on and don't worry about it.
dailystromfix is offline
post #3 of 3 Old 05-10-2010, 06:39 PM
BOURBON BOY's Avatar
I would try some fine (brown) Scotch-Brite and go with the grain of the brushed finish. Don't apply much pressure and go straight in line with the grain! You can also spray some WD-40 on the Scotch Brite to help speed up things a bit, but go easy, any good hardware store should have it. Cheers--BB
2012 Wee
BOURBON BOY is offline
