Bugs on Forks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 05-08-2010, 12:10 PM Thread Starter
Bugs on Forks
After a long ride I noticed there were quite a few dead/dried up bugs on the inner fork tubes. As you all know these bugs dry up very hard. I can't imagine these bugs are too good for the dust/fork seals when the suspenson compresses. I cleaned them off for now, but perhaps a fork tube guard would help.
I wonder if anyone has experienced this as well.
2011 Bullet SXR1100
2009 DL650
Gray Devil is offline
post #2 of 13 Old 05-08-2010, 12:20 PM
nvr2old's Avatar
I try to clean them off after each ride. Still had to clean the seals 2 times due to the bugs. Used the 35mm film trick.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 13 Old 05-08-2010, 12:30 PM
My solution is Rancho RS 1952 shock boots. Right now I have the bottoms cut off at the second pleat from the bottom and resting against the fork brace on their own springiness. They do limit suspension travel, especially if the tubes are raised. I have mine raised 13mm and use the boots to also prevent the ABS brake junction from hitting the fork brace. I'm willing to sacrifice some travel since I want the brace and the raised tubes for better handling, high speed stability and wind gust behavior. With heavier springs and riding only on pavement, I'm very pleased with the compromise.
post #4 of 13 Old 05-08-2010, 12:54 PM Thread Starter
Greywolf,
I like the fork boots and only 5 each! Nice solution.
2011 Bullet SXR1100
2009 DL650
post #5 of 13 Old 05-08-2010, 01:42 PM
Wulf
Those shock boots are a great idea. How do you install those?
post #6 of 13 Old 05-08-2010, 01:51 PM
The forks have to come off to slide the boots on. Think of it as a good chance to change the fork oil.
post #7 of 13 Old 05-08-2010, 02:40 PM
honest bob's Avatar
Or you can extend the "Bat Ears". It's just a piece of a mudflap riveted to the back of the Ears.
honest bob is offline
post #8 of 13 Old 05-08-2010, 04:44 PM
That looks factory made is it or are you just good. oops just seen the end of the text.
Bikes
1st=FZR 1000Exup
2nd=YZF 600
Now=2004 DL650 V-Strom:coolgleamA:
putbinoot is offline
post #9 of 13 Old 05-08-2010, 06:03 PM
honest bob's Avatar
Both You would wonder why it is not factory, oh wait, they want to sell parts too.
post #10 of 13 Old 05-08-2010, 06:18 PM
joe camarda's Avatar
greywolf...can you share with us where you got the fork boots?
nevermind...someday I'll learn to look before I ask. http://www.amazon.com/Rancho-RS1952-.../dp/B000CPCCFY
"I never trust my inner feelings...
Inner feelings come and go".
Leonard Cohen
joe camarda is offline
