Cab clearance lights for turn signals? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-06-2010, 11:01 PM Thread Starter
After searching numerous turn signal threads I have decided that I want to replace the expensive stock turn signals with a large flush mount. A couple members on here have installed truck cab lights as flush mounts. I like this setup, but I hate to go to an amber lens when I have clears now.
I have been looking at the Recons and am wondering if anyone has installed pair of clear cab lights on their Strom.
Dontbanme is offline
post #2 of 12 Old 05-07-2010, 08:12 AM
steve68steve
:lurk5:
I'm right there with 'ya, brother:
I recall seeing some cheapy flush-mounts at a either Cycle Gear or a local dealer - can't remember which.
post #3 of 12 Old 05-07-2010, 08:19 AM
Lockhart Phillips Flush Mount III. You can get them in clear. They're good size (not like the little sportbike marker lights), and have good visibility. And their not LED, so you can just wire them up and the blinker speed stays the same.
http://lockhartphillipsusa.x-shops.c...MOUNT-III.html
Check out ebay, BikeBandit, etc.
cbennett5199 is offline
post #4 of 12 Old 05-07-2010, 09:35 AM
av8or's Avatar
Send a message via AIM to av8or Send a message via Yahoo to av8or
do they use standard 1156 bulbs or the wacky bau15s socket with offset pins that the new stock signals use?
(to replace incandescent bulbs with led ones)
[COLOR=Blue]'07 Suzuki DL1000 V-Strom[/COLOR]
av8or is offline
post #5 of 12 Old 05-07-2010, 11:54 AM
gir
gir's Avatar
My bike came with the amber flush mount lights you're talking about -- at least that's what it sounds like. They're bright enough and use the standard bulbs, plus, if they should ever break, I'm sure I could replace them for like $5 at a truck stop.
The awesome part is that I also have the original unbroken turn signals in a bag
'04 DL650
gir is offline
post #6 of 12 Old 05-07-2010, 12:33 PM Thread Starter
Cbennett,
Do the ones you suggested cover the factory fairing holes?
post #7 of 12 Old 05-07-2010, 12:36 PM Thread Starter
Steve,
What do you plan to replace your stock broken TS with?
post #8 of 12 Old 05-09-2010, 11:51 PM Thread Starter
BUMP for further comment
post #9 of 12 Old 05-10-2010, 02:03 AM
steve68steve
Originally Posted by Dontbanme View Post
Steve,
I'll go find 'em and try 'em. I think they were only $20. I've seen quite a few pics of Stroms with flush mount turn signals to replace (or prevent) broken OEM signals - must be lots of choices out there.
Google found http://www.sportingforless.com/servl...F-R1-R6/Detailin a few clicks.
The only possible issue would be that the flush-mounts don't entirely cover the holes where the stalks of the OEM turn signals come thru the fairing. It's hard to imagine, given the smallish size of the stalks, that it would be an issue... but if it were, it seems like it'd be pretty easy to make an escutcheon plate out of plastic sheet or something scrounged
post #10 of 12 Old 05-23-2010, 11:07 PM Thread Starter
Any luck with the LPs?
