16T Sprocket? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 05-05-2010, 10:42 AM Thread Starter
16T Sprocket?
I am strongly considering going with a 16T sprocket on my '06 Wee. But I have 2 questions for you guys:
1) Do I need to remove (break) the chain to perform the job?
2) I've already installed a corrective speedo face to correct the MPH issue. Will putting on the 16T sprocket throw my MPH off again?
Thanks in advance for your words of wisdom.
acududeman is offline
post #2 of 21 Old 05-05-2010, 10:53 AM
Cat Herder
LowAndSilent's Avatar
1) Do I need to remove (break) the chain to perform the job? No. Just loosen up your rear axel, kick the tire forward to get enough slack in the chain to pull it off the front sprocket.
2) I've already installed a corrective speedo face to correct the MPH issue. Will putting on the 16T sprocket throw my MPH off again? Eh...no. The Strom works off a speed sensor on the front wheel. Changing tire sizes throws it off, not your sprocket.
See above.
'09 VStrom DL650A - Sold.
'04 Suzuki Burgman 400 - The wifes
'08 FJR1300AE - Miss Chievous.
WWGWD?
LowAndSilent is offline
post #3 of 21 Old 05-05-2010, 10:55 AM
I had a 16T put on a few weeks ago and love it.
Dealer put it on without messing with chain.
Speedo runs off front wheel(I think) so it will still be off.
[SIGPIC][/SIGPIC]Out there looking for myself.
No luck yet.
Groucho is offline
post #4 of 21 Old 05-05-2010, 09:10 PM
TomStromie's Avatar
I move to the 16 tooth sprocket at 22,000 miles (now at 43,000 miles) and then wished I had done it when I first bought my Wee.
TomStromie is offline
post #5 of 21 Old 05-05-2010, 10:10 PM Thread Starter
Perfect......thanks for the heads up.
I'll be puttin' on the 16T sprocket this month then.
post #6 of 21 Old 05-05-2010, 11:01 PM
Chucksklrst's Avatar
What is the RPM drop with a 16 tooth sprocket over a 15 tooth?
Chuck Henderson
(US Army RET)
(Forever Home Colorado)
https://www.facebook.com/chuck.henderson.980
RIDE a little FASTER, RIDE a little FURTHER
14 FJR1300A (Ruby Red)
19 Versys 1000LTSE (Flying Nun)
17 VX300 (Little Gray Bike)
Chucksklrst is offline
post #7 of 21 Old 05-05-2010, 11:09 PM
jonny's Avatar
If I remember correctly it's about 300 RPM drop
jonny is offline
post #8 of 21 Old 05-06-2010, 07:02 AM
dbrent's Avatar
I replaced my chain and sprockets this spring, going to the 16T. I like that the bike has longer pulls before needing a shift, and I can cruise at 50 mph in 5th gear at about 4k rpm. It truly makes 6th an overdrive.
However, I am evaluating the mpg performance and thinking about going back to a 15T. I thought the bike might get better mpg--not that I'm complaining. But, with about a 2,000 miles on the new set up, it seems to be getting slightly poorer mpg. I think it's because the engine is under more load dealing with the taller gearing.
Anybody else have this experience?
Brent
D. Brent Miller, writer, photographer, publisher
www.DBrentMiller.com
I traded my yellow 2008 DL650 for a 2015 White DL650ABS, and traded that one for a new 2017 white DL650ABS. My 3rd V-Strom.
dbrent is offline
post #9 of 21 Old 05-06-2010, 07:15 AM
Rjsurfer
Does the DL1000 run off the front wheel? if it doesn't, speedo will be effected.
Ron W.
07 Wee
07 DRZ400 SM (wifeys)
16 T Sprocket
Short screen & Washers
Replaced 'P" shooter
35W halogen rear signals
RT Gold Valves
Sonic Springs
rjsurfer is offline
post #10 of 21 Old 05-06-2010, 07:21 AM
Strom Chaser's Avatar
15/16 of a reduction, so it depends what original RPM you are talking about eg. 5000 RPM becomes 4687 RPM.
06 DL650
Strom Chaser is offline
