Mastad - Top Position - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 05-03-2010, 09:32 PM Thread Starter
Anyone have the Madstad bracket installed in the highest mounting position with the stock shield? This appears to be the best setting for me, however it looks as if the shield is flexing a lot during a ride and I am concerned this could cause the shield or the plastic at the base of the bracket to crack.
I think to be safe I will lower the bracket to the middle setting and order myself a Givi screen.
Just curious if anyone else has their Madstat installed at the highest setting and if it caused any problems - even the manual that came with the bracket does not recommend this position.
Cheers.
ghostrider66 is offline
post #2 of 10 Old 05-03-2010, 09:47 PM
Joe-V's Avatar
I have the Madstad mounted in the highest position on my '07 DL1000, with the windshield in the highest position about 75% of the time, and have had no issues.
[FONT="Trebuchet MS"][SIZE="2"][/SIZE][/FONT]
2007 DL1000
suzuki gel saddle & alaska sheepskin buttpad, K&N, rick's mirror extenders, grip puppies, powerbronze tall touring windscreen, madstad bracket, givi e460 top case, givi e36 side cases, rick's fork brace & rick's wheel spacers, givi crash bars, aprilia tuono mirrors, and sw motech center stand, and, as of 9/9/10, rick's footpeg & controls lowering kit.
Joe-V is offline
post #3 of 10 Old 05-04-2010, 09:22 AM
Are you refering to the 3rd postion or the "secret" 4th position?
mikeg
K5 Wee (Blue)
mikeg is offline
post #4 of 10 Old 05-04-2010, 10:10 AM
I've had my Givi tall screen mounted at the highest Madstad position since day one (a year ago). There is some flex, esp at higher speeds, but overall it seems to work well.
The only problem I've had is that the Madstad allowed the shield to creep backward at higher speeds, no matter how tight the thumbscrews. I finally used four small bolts to firmly lock the shield in a position that I'm happy with.
In this regard I found the Madstad poorly designed.
Peter
PipeLinePete is offline
post #5 of 10 Old 05-04-2010, 10:20 AM
UBarW's Avatar
I have mine all the way up, and forward. With the vent in there, I think it probably releases a lot of tension. But still... I am not worried about it...
Proud Member of the Patriot Guard Riders-Id: 79170
Major Joseph Y. Echanis, USAF Laos 11-5-69 Is not Forgotten...
UBarW is offline
post #6 of 10 Old 05-04-2010, 10:33 AM
MikeB's Avatar
That's odd. Even with a barn-door-sized V-Stream shield at the highest position I have not experienced that.
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
post #7 of 10 Old 05-04-2010, 11:05 AM
Banned
You have more dollars than sense.
Rashnak is offline
post #8 of 10 Old 05-04-2010, 12:34 PM Thread Starter
mikeg
The 3rd position I think?? Not sure what the secret 4th position is.
I am using the top 2 holes on the cowling.
post #9 of 10 Old 05-04-2010, 01:09 PM
Bracket slipping
I experience the same condition mentioned ie. windscreen slipping backward. Finally installed those saw tooth edged lock washers that you frequently see on electrical connections. The windshield is the large Givi and it no longer moves.
Bill S is offline
post #10 of 10 Old 05-04-2010, 04:26 PM
Robmiester's Avatar
Thanks for the tip, I too have had that problem.
Candy Orange Max DL650K9 fully farkled
Previous Rides (all long gone) :cry:
'75 Honda CB125 (Candy Riviera Blue) too cool cable actuated front disc break
'82 Honda FT500 Ascot (Red) rode that thing all over California
'01 HD 1200XL Sportster (Black) vibrated my nuts off
'98 HD FLHRCI Road King Classic (Black) big, fat, comfortable beast
'85 Honda Nighthawk CB650SC (Candy Scorpio Red) ahead of its time
Too many dirt bikes to list
Robmiester is offline
