Pelican cases - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 05-03-2010, 08:25 PM Thread Starter
Ex- moderator
Pelican cases
Which Pelican cases work the best on the V?..which racks are used and do the pelican cases require drilling or any modification to use as m/c side cases?
Why Motorcycles? Because Golf, Soccer, Football and Baseball only require One Ball
CollingsBob is offline
post #2 of 11 Old 05-03-2010, 08:35 PM
BOURBON BOY's Avatar
http://www.newenough.com/parts/dual_...em_suzuki.html I don't know if this is cheap or not, but I saw them the other day. Cheers--BB
2012 Wee
BOURBON BOY is offline
post #3 of 11 Old 05-04-2010, 10:57 AM
I used Givi PL528 and bolted a pair of 1550s right to them. Total cost came to about $500 (racks and cases), plus some hardware.
The Givi PLX528 are different, don't order them if you want to use the Pelicans.
I didn't drill through my Givis, but instead used U-bolts to mount the cases to the steel tubes. This creates a much stronger mount.
Peter
PipeLinePete is offline
post #4 of 11 Old 05-04-2010, 12:37 PM
Peter
There is also a puck mount system you could use if you want something that is more easily removable.
Geaux Tigers!
2007 DL650
Fully farkled
seawolf06 is offline
post #5 of 11 Old 05-04-2010, 02:52 PM
henerythe8th's Avatar
Some of us have also gone the top loader route.
Search for posts by henerythe8th or stevet in the luggage thread.
2011 MG Stelvio
henerythe8th is offline
post #6 of 11 Old 05-04-2010, 06:18 PM
Dorzok's Avatar
probably the most affordable setup with Pelicans. removable too!!
https://www.stromtrooper.com/showpost...&postcount=418
https://tciproductsusa.com/index.php...roducts_id=710
Somtimes it sucks not being in the loop. HUH??[FONT="Comic Sans MS"][SIZE="2"][COLOR="Olive"][/COLOR][/SIZE][/FONT]
Dorzok is offline
post #7 of 11 Old 05-04-2010, 06:20 PM
WildWildIp's Avatar
1550s on SWMotec EVOs....
"I see so many low mileage used bikes for sale with tons of $$ burnt on farkles...this forum needs a farkle captain. In order to get a bash plate you have to post a pic of your Wee on a trail where you would need one. The farkle captain would then approve that trooper to buy a bash plate because they earned it" -Timshel!
WildWildIp is offline
post #8 of 11 Old 05-04-2010, 06:32 PM
Originally Posted by Dorzok View Post
Do you know if that rack can be bought without the cases? I'd prefer top loading cases, even though they're smaller.
Geaux Tigers!
2007 DL650
Fully farkled
post #9 of 11 Old 05-04-2010, 06:53 PM
side cases
I went this route just recently. A bit more $$, but no drilling required.
Also excellent customer service.
http://cariboucases.com/store/?name=Home
acududeman is offline
post #10 of 11 Old 05-04-2010, 09:21 PM
Dorzok's Avatar
i believe Tom'll quote you a price without cases. give him a call. you do nee to make sure that whatever cases you use are large enought for the mounting hoop which are about 9 3/4" square.
Dorzok is offline
