Oil Filter stuck! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 26 Old 04-29-2010, 04:14 PM Thread Starter
OKState311's Avatar
Oil Filter stuck!
Ok, so trying to change my oil this morning, can't get the oil filter off. Maybe I put it on too tight last time, not sure. Usually comes off just fine with the cap-type wrench. Tried using plier-style wrench too, just makes lots of dents and scratches and can't get enough of a squeeze on it. My tools around the house are a little limited. Any tips on trying to get this badboy off?
K7 Silver 650
Go Pokes :bom_cowboy:
OKState311 is offline
post #2 of 26 Old 04-29-2010, 04:24 PM
You can drive a screwdriver through the body. It's messy and you are really committed once you try it though.
post #3 of 26 Old 04-29-2010, 04:34 PM
Location: Columbia SC, right in the center of the state.
Next time be sure to oil the rubber gasket on the filter and amen to the scredriver through the filter. It is messey but it works!
dirtrider1 is offline
post #4 of 26 Old 04-29-2010, 04:35 PM
eye.surgeon's Avatar
If you have to you can get a crush-type filter remover, like big plyers, it crushes the filter to give you some engagement points on the filter so you can put a lot more torque into turning it off.
'09 Wee (sold)
2012 Ducati Multistrada 1200 S Touring
2006 BMW K1200LT
eye.surgeon is offline
post #5 of 26 Old 04-29-2010, 04:39 PM
Ditto on the screwdriver. A 16"+ pipe wrench will also do the job.
wkat is offline
post #6 of 26 Old 04-29-2010, 05:23 PM
bigboy292000's Avatar
+1 on pipe wrench...
My OEM (original) filter that the bike came with was put on by the incredible Hulk. I actually broke a (plastic???) oil filter attachment/wrench that I bought at Autozone and did not want to use the screwdriver trick because of the mess. But pipe wrench did it. Did deform the filter but no leaks.
09 WABS w. some farkles & teeth
[URL="https://www.stromtrooper.com/showthread.php?t=35638&page=3"]Strom Squadron Member #5[/URL]
bigboy292000 is offline
post #7 of 26 Old 04-29-2010, 05:34 PM
Stromtrooper.com Sponsor
happypuppy's Avatar
Get a belt strap wrench. Then go buy a K&N Filter with a wrench type top. In over 35 years of working on bikes and cars I have never had a leak or a stuck filter by tightening by hand as firm as possible and then a 1/4 twist with a wrench. +1 on oil on the O ring.
happypuppy is offline
post #8 of 26 Old 04-29-2010, 05:39 PM
PNWStrom's Avatar
Get thee to a Harbor Freight Hardware store. You can get the above mentioned tool for a few paltry dollars and it works so well.
Chinese political prisoner labor is dirt cheap...apparently...
2013 DL650A
2009 DL650A-Gone to a good home
2009 KLR-Gone to a good home
PNWStrom is offline
post #9 of 26 Old 04-29-2010, 05:41 PM
AppGap's Avatar
Try a strap wrench next..then a pipe wrench...then big channel locks to crush it a bit...save the screwdriver as last resort. Makes a real mess and likely one of the other methods will do it. Another good argument for making sure you lube the O ring before installing a new one.
04 Wee with all kinds of excess crap..
AppGap is offline
post #10 of 26 Old 04-29-2010, 06:32 PM
Never
Never had a filter that wouldn't come off with one of the steel strap style wrenches. Worst-case scenario, wrap a little sandpaper (rough side in) on the filter before applying wrench. Wrenches run about 5 bucks at auto stores. Just be sure to get the right size (take the new filter along).
Jimding is offline
