Wolfman Large Expedition Tank Bag - what say you? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 04-25-2010, 10:03 PM Thread Starter
rebeccav's Avatar
I'm about to pull the trigger on a new Wolfman Large Expedition Tank Bag for my Wee.
Is anyone using one of these and if so, what are your impressions? Is it easy to get in and out of? Does it's harness keep it on the bike securely? TIA.
rebeccav is offline
post #2 of 14 Old 04-26-2010, 06:54 AM
ockerstrom's Avatar
More importantly
Can you see over it
I have looked at the Wolfman expedition tank panniers, the straps are too short to reach across the Wee tank and crash bars but the expedition panniers have buckles at each end so longer straps are easy to do, the other tank panniers they make have the straps sewn to one pannier so can't be lengthened as easily.
The advantage to tank panniers is they carry the weight lower and can help protect the bike in a fall [saw a pic somewhere of a Wee on it's side, the tank panniers and the rear panniers basically kept the rest of the bike off the ground].
I use an Oxford expandable tank bag [had it on my BMW R1150GS] but not enough of the magnets get a good grip due to the Wee's plastic so I use an ockie strap through the front carry handle on the bag to the crash bars on each side, I found the flaps lifted at 150/180kph.
I tried the bag on backwards and it was better but I'm still not happy to trust just the magnets.
Ock. in Oz
I ride naked and unafraid.
Windsor (near enough)
NSW
Australia
ockerstrom is offline
post #3 of 14 Old 04-26-2010, 07:10 AM Thread Starter
rebeccav's Avatar
I have the regular Wolfman tank panniers and they fit fine on my Wee.
A tank bag attached with magnets isn't going to work for me for touring/camping.
rebeccav is offline
post #4 of 14 Old 04-26-2010, 08:27 AM
ockerstrom's Avatar
Strange, tried both the standard and expedition tank panniers on my Wee last week and the straps were too short on both
The Oxford bag magnets held well at over 220kph on the GS, just not enough tank metal exposed for the front magnets to grab the Wee tank, they sit on the plastic.
I toured three states for two weeks and 4600km late last year with the tank bag, no problems other than the need to use the ockie strap for peace of mind, quick and easy to remove when refueling.
I'm off again for four days next weekend.
I will have my "tent bag" [tent, sleeping bags, sleeping mattresses, chair, etc. all in the one bag] strapped to the new rack I just fitted https://www.stromtrooper.com/forums/s...ad.php?t=52268 plus a pair of RJays expedition panniers [not using the Givi hard cases this time] and the tank bag will go on the tank [again] to carry my "on the road" munchies, water bottle, first aid kit, torch, plus other bits and pieces.
There is no doubt I carry too much with me but I'm still going to add tank panniers when I find ones that suit me
Ock. in Oz
NSW
Australia
post #5 of 14 Old 04-26-2010, 08:59 AM
How much of a PITA is it to remove for gas filling??? Just throwing that out there to ponder...........
www.easternvstromrally.com
mark444 is offline
post #6 of 14 Old 04-26-2010, 09:21 AM
JPryce's Avatar
I'm going on 2 years with mine. Love it. Perfect fit for the Stroms and as with everything else Wolfman, top quality. 4 straps hold the bag on the bike. The 2 straps you can see in the photo hold the bag closed. Inside, there is a strap you can run across the inside, as well as a draw-string closure you can use or not for extra protection. That bag is waterproof right up to the point where you actually go under water.
To gas up, I found the easiest way was to simply disconnect the 2 front straps and swing the bag to the side.
2012 Super Tenere
2006 CRF50 with big-boy mods. :biggrin:
1973 RD350
JPryce is offline
post #7 of 14 Old 04-26-2010, 10:40 AM
I have an Explorer Lite and it's worked great on my wee. Got it for a KLR and swapped it over to the strom. Works great. I think the Ex lite is 2" shorter than the expedition. I've had mine in some pretty good downpours and it keeps the contents relatively dry with just the cordura nylon. I'd bet the expedition will keep things really dry. The 4 point attachment keeps the bag very stable.
SPLATTE is offline
post #8 of 14 Old 04-26-2010, 11:41 AM
MikeB's Avatar
Why is that?
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
post #9 of 14 Old 04-26-2010, 01:12 PM
dbrent's Avatar
Last year, I was provided an Expedition for my Pony Express Trail adventure, and it is a good bag--very waterproof. I should know, I rode 500 miles in the rain for that whole trip. I also own a Wolfman Ranier, which I really like. The bag straps down tight, and does not flop around. For fueling, I disconnect the two back clips and flip the bag over the handlebars. Very simple procedure to fuel up and then secure the bag again. At first, I unclipped one of the front and slid the bag to the side. Flipping forward is better. The one feature I did not care for is what keeps everything dry. The lid for the bag makes it a two-handed process to get into it. I like the zipper of my Ranier much better. I can unzip and reach in for the camera or other items with one hand. Although the Ranier utilizes a rain cover for waterproofing, the Expedition is waterproof from the start. --Brent
D. Brent Miller, writer, photographer, publisher
www.DBrentMiller.com
I traded my yellow 2008 DL650 for a 2015 White DL650ABS, and traded that one for a new 2017 white DL650ABS. My 3rd V-Strom.
dbrent is offline
post #10 of 14 Old 04-26-2010, 06:48 PM Thread Starter
rebeccav's Avatar
Originally Posted by dbrent View Post
......The one feature I did not care for is what keeps everything dry. The lid for the bag makes it a two-handed process to get into it. I like the zipper of my Ranier much better. I can unzip and reach in for the camera or other items with one hand. Although the Ranier utilizes a rain cover for waterproofing, the Expedition is waterproof from the start. --Brent
Yeah, I was worried about that. Sounds like I need to balance my need for a waterproof bag with my need for ease of use and one-handed access.
Thanks much for your input everyone.
rebeccav is offline
